MFpsrig Posted January 16, 2024 Share Posted January 16, 2024 Hi, is there any way of creating several of the same symbol all at once using the Select similar tool? Just as an example, let's say I have fifty extrudes or generic solids all exactly the same. Now instead of using one of them, make it a symbol and then replacing all the extrudes or generic solids manually. Is there a way I could select them all and turn them all into the same symbol? Quote Link to comment
Tom W. Posted January 16, 2024 Share Posted January 16, 2024 Create your symbol first then select all the Extrudes + go to Modify > Convert > Replace with Symbol... This will replace all 50 Extrudes with instances of that symbol in one hit. Apologies if I've misread your post + this is in fact what you're doing already 3 Quote Link to comment
loic.jourdan Posted January 16, 2024 Share Posted January 16, 2024 Thanks Tom, I was having a similar issue and had no idea about this workflow, that's super helpful. 1 Quote Link to comment
MFpsrig Posted January 17, 2024 Author Share Posted January 17, 2024 Thank you! I did not know about that command! That is super helpful, exactly what I was looking for! 1 Quote Link to comment
