Cookie_NZ Posted January 12 Share Posted January 12 Hi all, I'm enjoying experimenting with Graphic Legends as an equipment summary. The legend image seems to select a specific instance of a lighting device to display. Some of my lighting devices in my file have custom plan rotation, so appear rotated in the graphic legend. Is it possible to force a graphic legend to ignore custom plan rotation? Or, is it possible to select a specific instance of a lighting device for the graphic legend to display? Cheers, Cookie Quote Link to comment
markdd Posted January 12 Share Posted January 12 (edited) Hi Cookie There are two options that I know of: Try using the Symbol definition as opposed to the Plug-in. The graphic legend will look at the first instance of every Plug-in in the file. I have had some success with selecting a particular Lighting Device that I want to use and then using the Send command to Send it to the Back. That will re-order its position in the database and give you the result you need. Edited January 12 by markdd 2 Quote Link to comment
Cookie_NZ Posted January 12 Author Share Posted January 12 Hi Mark, That's fantastically helpful information. Much appreciated. Cheers, Cookie Quote Link to comment
