Liam Whitney Posted January 11, 2024 Share Posted January 11, 2024 I'm trying to run pre-vis with an MA2 Full-Size and Vision 2023. Every fixture has a universe and channel value, and the built in data viewer sees sACN on all the right universes, however non of the fixtures in Vision respond. Is there something I'm missing? I've done this plenty of times before with onPC, but the full console should behave no different, especially since Vision can see the data. Thank you, Liam Quote Link to comment
Vectorworks, Inc Employee TomWhiteLight Posted January 15, 2024 Vectorworks, Inc Employee Share Posted January 15, 2024 Do you have the MA VizKey? I don't think you need it for sACN but am not 100%. If Vision can see it, then it should respond. So long as the input is set to sACN. Quote Link to comment
Vectorworks, Inc Employee klinzey Posted January 16, 2024 Vectorworks, Inc Employee Share Posted January 16, 2024 As long as you are set to sACN everything should be fine. Disconnect or disable any network interfaces that are not needed. Vision listens to all network interfaces but we have seen issues where Vision gets conflicting information if multiple interfaces see data. I do recommend using a 3rd party sACN viewer whenever you are having issues just con confirm the data and to check the universe. The one thing to remember is that if you are looking at raw sACN data the universe is off by 1. The first universe in sACN is 0 which is universe 1 in most interfaces. 1 Quote Link to comment
