type11
Bring back the Extend Tool
We all want it back!
The Connect/ Combine tool cannot extend multiple lines of varying length to another line with a single click.
It's a real step backward to have to individually click and drag each line you want to extend.
19 answers to this question
Call. NNA, it's time to bring back this useful feature, especially since AutoCAD has a similar capability. Eliminating the extend tool was a step backwards. I imagine many people use it as I once did, to project lines from a floor plan to create an elevation or section.
[ 01-20-2003, 01:48 PM: Message edited by: P Retondo ]
In which version of VectorWorks did this capability exist? I've been back through a number of old versions and can't find an extend tool that does this.
Regards,
Sean
I last remember seeing the Extend Tool in VW 8.52.
I think VW 9 is where it was removed.
I had hoped to see it come back in VW 10...
From the tests I've run and old manuals that I've read, this was never a capability of this tool in 8.5 or 8.0 from my tests. I think its a good wish, however, for a new feature.
Best Regards,
Sean
I also miss the extend tool and wish to see it come back. But I never used it for extending multiple lines with one click.
I am also curious what version of Vectorworks allowed this behavior. The extend tool existed in version 8.5.2, but I just sampled it in both the offered modes with all different combinations of lines selected, and I could not get it to extend more than one line at a time.
Either way, I would certainly like to have this ability in a future version.
I fired up an old version of VW 8.52 to examine the extend tool.
As it turns out you can't extend multiple lines to a boundry with a single click. You have to click each line in order to extend it. This is still way better than having to click and drag each line as in VW 9/10.
I was confusing the old extend tool with an OzCad plugin by Julian Carr. He had an Extend to Line tool that worked very well. I am not sure if these plugins work with VW10.
I would love to see Extend to Line and Extend Multiple Lines to Boundry in the next rev. of VW.
Essentially, the connect combine tool (second mode) does this.
You click on the one line, then click on the other line and it will drag the one line to meet or extend to the other one.
Alternately, you can select several lines and stretch them to be really long using the 2d tool at one time. Then switch to the split by line/point tool using the Split by Line mode and split the horizontal lines with a vertical line. This will break the lines at that intersection point. Then you can delete the bogus lines.
OR you can use a vertical line on horizontal lines as a trimming line. Using the Trim tool, click on the lines and pick them off one at a time.
There are lots of different ways to get the same result.
Sean and Katie,
Perhaps you are somewhat misled by the way we are characterizing the use of the extend tool. With the old extend tool, you select the line to be extended to, select the tool, then click once on each of the lines to be extended. N.B.: the line to be extended to does not have to be in your view! It can be hundreds of feet away, and you can zoom in to see the individual lines to be extended, which may be inches or less apart! So besides one click for each extend, no panning and zooming between clicks. This is what we miss.
Better than just bringing back the extend tool, it would be great if there were a second mode where you could select multiple lines to be extended, then hit enter to extend them all at once.
[ 01-22-2003, 09:10 PM: Message edited by: P Retondo ]
quote:
Originally posted by P Retondo:
Sean and Katie,
Yes, clearly said. It's the "out of view" ability which makes the tool so useful, and a "multiple line" version would be more so.
- Carl
The beauty of the Extend tool in VectorWorks is tied to the ease with which rectangles and other surfaces can be created. In VectorWorks, I normally draw with rectangles, not with lines, and add and clip them to form shapes which can be easily re-shaped, filled, hatched, and given new line weight and dash pattern. Often it's necessary to fill one of those shapes with something for which a hatch doesn't work, or just extend several lines to the edge of a floor, wall, window, etc. It's easy and quick to select a polygon or surface, and then extend a lot of lines to its boundary, even if the boundary is off the screen.
In versions up to 8.5.2, the Extend tool had 2 modes. The first mode was useless because it required dragging the extendee to the boundary. Stretching with the Selection tool would be just as easy. The Second mode is the great tool everyone misses so much: select boundary object or objects, then select Extend tool (second mode), and then click once on each line that you want extended to the nearest boundary. No dragging. You have to click on the half of the line that's in the direction you want it extended. You can click again to extend to the next boundary after that.
I'm still using version 8, even though I bought the upgrade to 9, because of this problem and a few others which version 9 had. I'm looking at version 10 now, and it seems to me that it corrects all those other problems of version 9, and sometimes even improves on version 8. But it still doesn't have the very important Second mode of the Extend tool.
The Connect/Combine tool only works like the useless First mode of the Extend tool, i.e. by dragging, and only it extends a line in one direction. It's certainly not a replacement for the old Extend tool.
I think that this thread is a little more evidence that (some) users continue to care about improvements to 2D tools.
These tools may be old-fashioned and counter to the single model ideal, not interesting as a programming challenge, and insofar as they mimic ACAD, (extend tool, "fences") they may even contribute to loss of program character. But, they are efficient and useful for certain tasks.
- Carl
I have found the command routine from VW 7.03 that I use perhaps a hundred times during my normal drawing work day. It is CRITICAL to my descision to update to VW10. It was authored by Sean Flaherty himself. I use it as a command from my saved sheets pallette off the bottom scroll bar which I find more useful than as a traditional command. It allows single or multiple line extensions with a one click selection. I can email it to anyone who feels they can update it to work in VW10.
Thanks in advance,
Ian Kelshaw
Does anybody use the Extend Tool to extend arcs or polys to boundary objects, or is the majority of its use for snapping lines to boundaries?
Raymond
The code sent by Ian works perfectly on VectorWorks 9 and 10 without any modification.
It could be re-writen a lot simpler in VW10 but that's not the point. It can be used from a script palette or be made into a 'tool', like the others on the 2D Tools/Editing Palette.
regards,
Alexandre
[ 01-30-2003, 09:08 PM: Message edited by: Alexandre B A Villares ]
code:
PROCEDURE Extend;
{* by Sean Flaherty of Graphsoft, Inc. *}
{* Takes the selected lines and extends them to a line *}
{* chosen by the user. *}
VAR
theList, theObj : Handle;
whereX, whereY, px, py, vx, vy : REAL;
FUNCTION CrossP( x1, y1, x2, y2 : REAL) : REAL;
BEGIN
CrossP := x1 * y2 - x2 * y1;
END;
FUNCTION DistToV( x, y : REAL ) : REAL;
VAR
num, denom : REAL;
BEGIN
num := Abs( CrossP( x - px, y - py, vx, vy ));
denom := Sqrt( vx**2 + vy **2 );
DistToV := num / denom;
END;
PROCEDURE GetEquation( x1, y1, x2, y2 : REAL; VAR slope, off : REAL; VAR
inf : BOOLEAN );
BEGIN
IF x1 = x2 THEN inf := TRUE
ELSE BEGIN
inf := FALSE;
slope := ( y2 - y1 ) / ( x2 - x1 );
off := y1 - slope * x1;
END;
END;
PROCEDURE ExtendLine( u : Handle );
VAR
s1x, s1y, s2x, s2y, rx, ry : REAL;
FUNCTION SectToV( a1x, a1y, a2x, a2y : REAL ) : BOOLEAN;
VAR
infA, infV, tmpBool : BOOLEAN;
slopeA, slopeV, offA, offV : REAL;
BEGIN
GetEquation( a1x, a1y, a2x, a2y, slopeA, offA, infA );
GetEquation( px, py, px + vx, py + vy, slopeV, offV, infV );
IF infA & infV THEN tmpBool := FALSE
ELSE BEGIN
tmpBool := TRUE;
IF infA THEN BEGIN
rx := a1x;
ry := slopeV * rx + offV;
END
ELSE IF infV THEN BEGIN
rx := px;
ry := slopeA * rx + offA;
END
ELSE IF slopeA <> slopeV THEN BEGIN
rx := ( offV - offA ) / ( slopeA - slopeV );
END
ELSE tmpBool := FALSE;
END;
SectToV := tmpBool;
END;
BEGIN
GetSegPt1( u, s1x, s1y );
GetSegPt2( u, s2x, s2y );
IF DistToV(s1x,s1y) < DistToV(s2x,s2y) THEN BEGIN
IF SectToV(s1x,s1y,s2x,s2y) THEN SetSegPt1(u,rx,ry);
END
ELSE BEGIN
IF SectToV(s1x,s1y,s2x,s2y) THEN SetSegPt2(u,rx,ry);
END;
END;
BEGIN
theList := FSActLayer;
IF theList <> NIL THEN BEGIN
Message( 'Pick the line to extend to' );
GetPt( whereX, whereY );
ClrMessage;
theObj := PickObject( whereX, whereY );
IF ( theObj <> NIL ) & ( GetType( theObj ) = 2 ) THEN BEGIN
{* set the constraining vector *}
GetSegPt1( theObj, px, py );
GetSegPt2( theObj, whereX, whereY );
vx := whereX - px;
vy := whereY - py;
WHILE theList <> NIL DO BEGIN
IF GetType( theList ) = 2 THEN ExtendLine( theList );
theList := NextSObj( theList );
END;
END;
END;
END;
RUN( Extend );
[/code]
