Apologies if this has been addressed elsewhere, I did try to do my due diligence and look around; I either couldn't find it or didn't name the issue correctly.
In my Title Block, I'm linking both project and sheet data. Most fields are working correctly however I have two (Room Details and Scale) that are misbehaving. I set everything up the same so am at a loss for what is causing this.
From what I can tell, the two fields are not replacing the default data with what I've entered in the TBB Settings dialog.
Troubleshooting steps:
-Have cleared out the default data for these fields from the Record Format in Resource Manager.
-Have changed the fields these are linked to clear out the data and then set them back to the desired field.
sinukai
Thanks for all assistance.
7 answers to this question
