Create a surface bettwen two elipses (X,Y)
Hello, I drew an ellipse on the Z plane and another one on the Y plane.
Final Objective: draw half a solid like an egg.
Z plane:
X plane
How do I cut the bottom part of my sketch to keep only the upper part along the line that looks like a triangle?
Then, how can I create a surface that connects the ellipse in Z with the 'half ellipse in X'?
I tried NURBS and LOFT surfaces but without success.
Edited by Cristiano Alves
[Update]
I have some progress.
1- I use this ellipse:
2- Convert them to line
3- Delete some segments
4- At this time I try join the lines of the curve. Didn't work.
4.2- I used the NURBS Curve tool to draw a curve line with the points of the "old curve line"
5- On this view I use "Revolve with Rail"
image.thumb.png.d6a3269a3a23fa7be973cf4ebfe892ba.pngimage.thumb.png.6510c5fcbf32e827a56ec87c1dddcacc.png
The result is great:
The revolve was only applied to the blue line, I wanted to apply it to the Blue+Green line (see previous image).
However, I cannot bring these two lines together in any way.
I tried Join, but it didn't work, I tried Compose, but it didn't work either.
(I did this in Front view.)
The problem shouldn't be that the lines have coincident points, since I tried joining two lines outside of this example without success.
What is the tool to join two lines?
Can anyone help me?
And last one, this is a better and correct way to do this?
I think it is not a Tool but a Command.
"Compose" from the menu.
Also thought about Revolve.
But did not answer as I was not sure if it would work
a) that way in general and
b) with ellipses
I thought about starting with circles and arcs or just by a globe
and using 3D Manipulation Tools.
Which in effect would just do a nonuniform scaling .... which may
look pretty similar - but not the same as elliptical.
And so far i assumed true Ellipses are mandatory.
