setdesigner Posted December 1, 2023 Share Posted December 1, 2023 Any idea why I get a perspective crop on vectorworks 2024. Since I started using vectorworks in 2021, I never activated this feature, and never used legacy features. I used this script to turn it off Quote On 2/17/2023 at 11:42 PM, Pat Stanford said: Or even better solution. Go to the Resource Manager and Create New Resource of type Script. Paste the following line into the script editor. Double click on the script name in the Script Palette and it will toggle the crops on and off. SetPref(127, Not GetPref(127)); Just that one single line is all you need. Quote Link to comment
0 Pat Stanford Posted December 1, 2023 Share Posted December 1, 2023 Are you using a template file? If so, it is likely that that template has the Perspective Crop turned on. What happens if you start with a new blank file? Is the crop on or off? Quote Link to comment
0 setdesigner Posted December 2, 2023 Author Share Posted December 2, 2023 I started with my own template made from scratch with the 2023 version. It happened I think after updating an instrument summary. (The old version, I can't make the new inventory to show properly the count left...) Thanks Quote Link to comment
0 Pat Stanford Posted December 2, 2023 Share Posted December 2, 2023 So try this. Open your template file. Go to Document Preferences:Legacy 2D. Check the Enable Legacy 2D Features check box. Close Docuement Preferences Open Document Preferences:Display pane At the very bottom of the list there should be a Crop Perspective View option. Is it checked? If so, uncheck it and close Document Preferences. Close Document Preferences. Open Document Preferences Check that Crop Perspective View is still unchecked. Go to the Legacy 2D pane and uncheck the Enable Legacy 2D Features check box. Close Document Preferences. Go to File:Save as Template. If you are brave, just overwrite your existing template. Or Save it as a new template, but then you have to remember which one to use. Good luck. I hope this helps and solves the problem. Quote Link to comment
0 setdesigner Posted December 2, 2023 Author Share Posted December 2, 2023 Thanks, I did this process with my file, but it came back. Your script worked, and so far it is solved. I will try this method on my template if it comes back, thanks for your help. Quote Link to comment
setdesigner
4 answers to this question
