Peter Telleman Posted December 1, 2023 Share Posted December 1, 2023 Hi everyone, It's one of those days where I'm busy trying stuff I've never done before. I have a set of scaffclamps that I've drawn myself. If I put them in the drawing with the lighting device tool, they snap neatly to the truss (so they can be used with braceworks). The issue I'm left with is weight. Braceworks tells me the symbols have no weight. How do I add weight to the symbols, so braceworks can recognize that? Is that by attaching a record and filling in a weight in the record? If so, what record would I use for these clamps? Can I make my own record? thanks in advance, Peter Quote Link to comment
markdd Posted December 1, 2023 Share Posted December 1, 2023 (edited) You should investigate the Rigging loads tool and the subsequent point load object. You can add symbols to this giving you the load indicated along with the clamp geometry. The resulting object can be saved as a plug-in symbol which you can add to your library. Edited December 1, 2023 by markdd Quote Link to comment
Peter Telleman Posted December 4, 2023 Author Share Posted December 4, 2023 Hi Mark, Do you mean set a point load with the weight of this clamp, and then with show symbol select the specific clamp? In topview this then still looks like a text with the weight, and not as a clamp (it does in isometric view). How do you save it as the plug in symbol? Quote Link to comment
markdd Posted December 4, 2023 Share Posted December 4, 2023 You need to add a 2D component to the Symbol otherwise you will get the generic blue circle. YOu can turn the weight indicator off using classes. Once you have a Point load object you are happy with, save it as a Symbol and ensure you have "Convert to Plug-in object" checked in the Create Symbol dialog. The result will be a Red symbol that you can use whenever you like. Quote Link to comment
