David Poiron Posted November 21, 2023 Share Posted November 21, 2023 Is there a way to easily split 3D objects into slices of consistent width, like in this image. I thought there was a video regarding this but I cannot seem to find it. Quote Link to comment
Kevin Allen Posted November 21, 2023 Share Posted November 21, 2023 I think you have to search "subdivision" to find that video. There are other ways but I would create a number of extrudes and subtract solids Quote Link to comment
VIRTUALENVIRONS Posted November 21, 2023 Share Posted November 21, 2023 You can slice an object into 3D planar contours using the Contours tool in the 3D tool Palette. This was likely made using Subdiision and then a consistent planar extrude was duplicated along the length. Those duplications were then subtracted from the main object using Subtract solids. Quote Link to comment
David Poiron Posted November 22, 2023 Author Share Posted November 22, 2023 I've ended up creating a 3D object with a slit in it and cutting copies of the original object (solid subtractions) and then reassembling the cut pieces back into the original shape. Quote Link to comment
