KingChaos Posted November 7, 2023 Share Posted November 7, 2023 hi, i am trying to manipulate this node. I need an input port (for my Layer name), which is the criteria in the filter. therefore it would be the best i can use this node , BUT its output port should not get the handle of the layer. it must output the "name" of the layer to let this get into the "objs by crit" node. i need a popup-driven "objs by crit" node 🙂 Can someone do this for me or help me with it? BR KC Quote Link to comment
FranAJA Posted November 13, 2023 Share Posted November 13, 2023 These are inputs itselves so can not have inputs. I did not get too much your intentions but something like Criteria Dialog can be helpful ? Quote Link to comment
KingChaos Posted December 15, 2023 Author Share Posted December 15, 2023 if i wanna filter the objects flown through the network with new criterias, it can be VERY powerful. the obj b crit. is analysing all the objects fitting to the criterie. i need it to filter the objects by criterias ONLY out of a given list of objects in the network which were filtered before completerly different. Quote Link to comment
KingChaos Posted December 15, 2023 Author Share Posted December 15, 2023 so I wanna have some Objects with DB entry in existing symbols in a seperate layer, without having any other stuff which is not specific db recorded. so i thought: 0. Clear layer2 (>the delete not has no output and the criterie node no input) so it is complicated for me to make both nodes into my existing network which does the following: 1. Filter all symbols here on layer1 "obj b crit" -> [is on layer 1 & is symbol] 2. i need to "symbol into group" them and ungroup it 1 time. so i have not symbols any more but a lot of groups instead of 1 group by the marionette. 3. place them onto an empty layer2. until here it works, but it won clear layer2 -> BUT If layer 2 is not empty before i have to delete all the stuff on layer2, BEFORE the symbols are getting groups. 4. duplicate all objects with a specific DB record onto layer3 Then i got all the stuff i need. The problem is, sometimes the db record is on groups (in my symbol, if it is an assembly) or on objects (if it is a single piece). all other attempts failed here. at first i tried to copy all the symbols to layer2 it failed because VWX placed all the symbols to the global point 0 so they are not in the location i placed the symbols. So i tried it in a different way. If i can use a crit node which is not filtering all the existing parts, i can filter the filtered objects and therefor i think i need such a node 🙂 Quote Link to comment
KingChaos Posted December 15, 2023 Author Share Posted December 15, 2023 lol this functionless input i placed in the nodes code is working in such a way, that it will filter all the stuff but AFTER the rest of the network is done. it is not what i needed, but i can use it. Nice would be the function i tried to describe before. Quote Link to comment
KingChaos Posted December 15, 2023 Author Share Posted December 15, 2023 not elegant, but it seems to work maybe now u know what i want ^^ symbol to group-Final.vwx Quote Link to comment
SimA Posted December 15, 2023 Share Posted December 15, 2023 Bringst du damit eine Marionette mit Bohrungen im Korpusgenerator zum laufen? Quote Link to comment
KingChaos Posted December 18, 2023 Author Share Posted December 18, 2023 nein, ich bringe VWX dazu fuer mich alles was meine Metallbauelemente anbelangt, zu duplizieren und symbole aufzuloesen, damit ich nichts mehr zeichnen muss. dauert bis 3 min bei ner normalen Datei. Quote Link to comment
SimA Posted December 18, 2023 Share Posted December 18, 2023 Zum Nachdenken. Nun, eine Marionette mit NC-Bearbeitungen funktioniert im Korpusgenerator nicht. Grund, es ist ein Rotes Symbol / intelligentes Objekt. Wenn wir das Symbol im KG nun dazu bringen würden, sich nach dem einfügen in eine Gruppe aufzulösen… … würden die Bohrungen funktionieren. Quote Link to comment
KingChaos Posted December 19, 2023 Author Share Posted December 19, 2023 ja cool, hat nur nichts mit dem thema zu tun ^^ aber du bringst mich auch auf eine idee. erklaer mal was du meinst, kannst du die symbol-to-group node dazu nicht benutzen? Ich frage fuer einen Freund 🙂 Quote Link to comment
KingChaos Posted December 19, 2023 Author Share Posted December 19, 2023 wie willst du denn die nc bearbeitungen in die marioette einbauen? als blaues symbol? mach doch einfach einen 3D Punkt mit in das symbo, dann wird es automatisch blau, oder? Quote Link to comment
SimA Posted December 19, 2023 Share Posted December 19, 2023 blau / rot Symbol... Wenn du ein Marionette Objekt as Symbol absicherst, dann ist es rot. Im KG brauchst du ein blaues. Ich frage mich, ob der "Objet auflösen Knoten" im KG funktionieren könnte. So würde aus dem roten ein blaues Symbol mit allen Funktionen. Soweit der Gedanke... Quote Link to comment
KingChaos Posted December 20, 2023 Author Share Posted December 20, 2023 habe ich schon kapiert ^^, es loescht nur leider das Symbol nicht, denn es erzeugt eine kopie als gruppe. Du muesstest das Symbol dann noch loeschen. Quote Link to comment
Antonio Landsberger Posted January 18, 2024 Share Posted January 18, 2024 On 11/7/2023 at 3:31 PM, KingChaos said: hi, i am trying to manipulate this node. I need an input port (for my Layer name), which is the criteria in the filter. therefore it would be the best i can use this node , BUT its output port should not get the handle of the layer. it must output the "name" of the layer to let this get into the "objs by crit" node. i need a popup-driven "objs by crit" node 🙂 Can someone do this for me or help me with it? BR KC Hast Du Dir das hier schon angeschaut? https://www.vectorworksforum.eu/topic/22032-marionette-obj-by-crit/#comment-96204 Quote Link to comment
KingChaos Posted January 18, 2024 Author Share Posted January 18, 2024 sehr geil, ja habe leider momentan keine zeit dafuer, aber danke vielmals. ich habe einfach einen toten inputport angebaut und eine andere obj b criteria "vorgeschaltet" 🙂 Quote Link to comment
