Modifying Bulk Stake Objects
AKieran
5 answers to this question
I think I figured that out also back in 2020.  The following script creates the Stake from a 3D Loci data but the setting of the Z value is a separate step than the Stake creation.  Not tested in 2024, but it compiles.
Procedure StakesFrom3DLoci;
{Inserts a symbol at the X/Y/Z location of each 3D loci on the active layer}
{© 2020,2008, Coviana, Inc - Pat Stanford pat@coviana.com}
{Licensed unde the GNU Lesser General Public License}
Var		H1,H2:Handle;
		X1,Y1,Z1:Real;
		N1,N2:Integer;
Begin
	H1:=FActLayer;
	While H1 <> nil do
		Begin
			If GetType(H1) = 9 then
				Begin
					GetLocus3D(H1,X1,Y1,Z1);
					Symbol('Your Symbol Name Here',X1,Y1,0);
					H2:=LNewObj;
					Move3DObj(H2,0,0,Z1);
					H1:=NextObj(H1);
				End
			else
				Begin
					H1:=NextObj(H1);
				End;
		End;
End;
Run(StakesFrom3DLoci);
If the scripts don't work...
You could create a worksheet with the data necessary (match a surveyor's point file) export the data to excel and use a formula in excel to multiply your values, then re-import (Landmark>Survey Input>Import Survey File...)?
I'm sorry this is only the basics of a workflow, but it might be somewhere to start?
Alternately you can use the Modify>move>Move 3D to move stakes with the same value a given amount. You would need to isolate them in vertical bands for selection to make this work and it could be tedious, but it's something?
