gester Posted September 27, 2023 Share Posted September 27, 2023 hi, another question after the viewing of the archicad 27 webinar: is it possible to do datavisualization in vectorworks file, except that not on the viewports, but directly in the model? e.g. colouring of the walls according to the different fire resistance (red - 60 minutes, orange - 30 minutes, yellow - 15 minutes) directly in the model, and save it for future views... thanks, rob Quote Link to comment
zoomer Posted September 27, 2023 Share Posted September 27, 2023 I have not yet used data visualization .... but AFAIK Yes. There is the Data Vis Menu in Top Bar. Quote Link to comment
gester Posted September 27, 2023 Author Share Posted September 27, 2023 for the viewports... Quote Link to comment
Tom W. Posted September 27, 2023 Share Posted September 27, 2023 Yes you can apply Data Visualisations to the model on the design layer + save them in Saved Views. They are very useful for interrogating the model as you design. As well as applying them to viewports as well of course. Quote Link to comment
zoomer Posted September 27, 2023 Share Posted September 27, 2023 Thanks, sorry, I thought I could activate it for DLs there. Quote Link to comment
zoomer Posted September 27, 2023 Share Posted September 27, 2023 1 minute ago, Tom W. said: Yes you can apply Data Visualisations to the model on the design layer + save them in Saved Views. Ah, OK. So yes. Quote Link to comment
Tom W. Posted September 27, 2023 Share Posted September 27, 2023 On the DL you control Data Vis from the View Bar drop-down like you say. For a VP you do it from the OIP (Tool Bar settings are greyed out on when on sheet layer). The Data Vis controls in VW2024 are very nice! 1 Quote Link to comment
gester Posted September 28, 2023 Author Share Posted September 28, 2023 (edited) 14 hours ago, Tom W. said: Yes you can apply Data Visualisations to the model on the design layer + save them in Saved Views. They are very useful for interrogating the model as you design. As well as applying them to viewports as well of course. so as i get it, for my initial wall colours visualization example: 1. i save the original view with my walls 2. i change the colours for those walls according to their fire resistance values 3. save this new view 4. recall the original saved view (must check if the original colours can come back) is that it? Edited September 28, 2023 by gester Quote Link to comment
Tom W. Posted September 28, 2023 Share Posted September 28, 2023 14 minutes ago, gester said: so as i get it, for my initial wall colours visualization example: 1. i save the original view with my walls 2. i change the colours for those walls according to their fire resistance values 3. save this new view 4. recall the original saved view (must check if the original colours can come back) is that it? Yes. Just make sure that at step 3 that you have 'save data vis' checked in the 'Save View' dialog. Quote Link to comment
zoomer Posted September 28, 2023 Share Posted September 28, 2023 6 hours ago, gester said: 2. i change the colours for those walls according to their fire resistance values In case I got you wrong ..... You do not need to change the Wall's Colors. You use Data Vis to temporarily overwrite the current object appearance. In this case, by defining Data Vis to use certain colors for fire resistances, which Data Vis reads from your object data/tags. Quote Link to comment
gester Posted September 28, 2023 Author Share Posted September 28, 2023 (edited) yeah, probably it'll be right. i just have to check, i'm not at the computer with the vw installation. Edited September 28, 2023 by gester Quote Link to comment
