Todd W Posted September 14, 2023 Share Posted September 14, 2023 I am trying to align the exterior sheathing to the underside of the roof sheathing. How do I do this? A clip of the model attached. I have the roof datum set to the underside of the sheathing. Thanks. Quote Link to comment
Tom W. Posted September 14, 2023 Share Posted September 14, 2023 Apply a top offset to the sheathing component in the wall settings 2 Quote Link to comment
Todd W Posted September 14, 2023 Author Share Posted September 14, 2023 Thanks Tom - I found that when I set the offset slightly higher than the underside of sheathing then clip it with the roof sheathing it hits the underside where I want it to. Quote Link to comment
Tom W. Posted September 14, 2023 Share Posted September 14, 2023 4 minutes ago, Todd W said: Thanks Tom - I found that when I set the offset slightly higher than the underside of sheathing then clip it with the roof sheathing it hits the underside where I want it to. On the eaves that's exactly what you need to do. Unless you actually want a square top edge to the boards, abutting the underside of the roof, which is more likely how it would be constructed in reality...? 1 Quote Link to comment
