line-weight Posted August 18, 2023 Share Posted August 18, 2023 I know there's a hyperlink tool (which I'm yet to try using) but what I actually want to be able to do, is have a block of text, where there's a hyperlink within the text, eg I might want a note on a drawing that says: Windows to be installed following all supplier guidelines, as per www.windowsupplier.com/installation guidelines This is not possible, is that right? 1 Quote Link to comment
TomKen Posted August 18, 2023 Share Posted August 18, 2023 I don't think you can embed the hyperlink into a text object. You can make the hyperlink label text whatever you want though. Quote Link to comment
line-weight Posted August 18, 2023 Author Share Posted August 18, 2023 Yeah, unfortunately doesn't let you have several different links within the same body of text though. Seems a bit of a basic thing to be missing - it's pretty standard in all sorts of applications now. These days many drawings never make it onto paper and will be viewed as PDF on screen - would be good to be able to have hyperlinks in general text and in things like notes callouts. 3 Quote Link to comment
