Thomas K. Posted July 27, 2023 Share Posted July 27, 2023 Hi when using the television tool and trying to insert the display (see vwx file with example below) I get an error " the symbol you have chosen is not a valid Television model or is incorrect for the type and aspect you have chosen." Once it lives inside the drawing it functions normal when you leave it alone. When you make changes the television tool is no more able to "see" this symbol. Any ideas? error 86inch.vwx Quote Link to comment
Thomas K. Posted July 27, 2023 Author Share Posted July 27, 2023 Solved it: I changed the database entry from TV -> Display. That caused an error. @C. Andrew Dunning: what is the tool using the "TV" for? Quote Link to comment
C. Andrew Dunning Posted July 27, 2023 Share Posted July 27, 2023 2 hours ago, Thomas K. said: Solved it: I changed the database entry from TV -> Display. That caused an error. @C. Andrew Dunning: what is the tool using the "TV" for? In the "__VS-ModData" Record "Type" must = "TV" for Television casing models. That same Record is also used by projectors and stands so that value is needed to differentiate between the different model types. I just tested this with the file you posted and things worked as-expected. Quote Link to comment
Bluetones Posted August 22, 2023 Share Posted August 22, 2023 (edited) I get a similar error when working with the Speaker Array tool. It tells me that " the symbol you have chosen is not a valid Television model or is incorrect", but not what to do about it. This for both VW symbols and for custom ones. @C. Andrew Dunning Help us Obi-Wan, you're our only hope... Edited August 22, 2023 by Bluetones Quote Link to comment
C. Andrew Dunning Posted August 22, 2023 Share Posted August 22, 2023 5 hours ago, Bluetones said: I get a similar error when working with the Speaker Array tool. It tells me that " the symbol you have chosen is not a valid Television model or is incorrect", but not what to do about it. This for both VW symbols and for custom ones. @C. Andrew Dunning Help us Obi-Wan, you're our only hope... If you're getting TV errors w. AudioArray 2, that is a REAL mystery... 😉 If you can send me a demo file w. step-by-step actions that produce a repeatable error I'll see if I can figure out what is going on. W/o both, it is going to be incredibly difficult (if not impossible) to figure out what might be going on. Quote Link to comment
Mark Aceto Posted August 22, 2023 Share Posted August 22, 2023 New seamless workflow? Quote Link to comment
