Stu Wilson Posted July 12, 2023 Share Posted July 12, 2023 Is it possible to plot a site using A.O.D data rather than working it all out manually by entering stakes all over the site on +/- levels from a datum point. We have a site that has levels set, for example +21.240 +22.00 and so on over AOD. Can this data be imported into a drawing via .dwg to set up a suitable site model or do i have to manually enter stakes using the .dwg sheet as an overlay? What I don't want to do is to actually design the site 22 meters above the page level of zero if that makes sense using the x value Regards Stuart Quote Link to comment
line-weight Posted July 12, 2023 Share Posted July 12, 2023 Do you mean Z value? And what do you mean by "page level"? Do you mean a dwg simply with text objects noting the AOD levels or do you mean a dwg that contains some objects that already have the right AOD z values in 3d space? Quote Link to comment
