fuberator Posted July 5, 2023 Share Posted July 5, 2023 Hi I want to put a clip cube isometric view on a sheet. I just can't figure out how to do it, is it even possible? Thanks for any advice Quote Link to comment
bcd Posted July 5, 2023 Share Posted July 5, 2023 The only way I can think of is to create a DLVP of your model on a separate DL, rotate it 30º on x & y and create a clip cube SLVP of that. Quote Link to comment
Jesse Cogswell Posted July 5, 2023 Share Posted July 5, 2023 (edited) It can be done (as long as you're not hoping for a Hidden Line viewport...)! The way to do it is to set your Clip Cube and view in Design Layer space, then select the Clip Cube and run the View - Create Viewport command. Set the layer to the Sheet Layer and your options accordingly, then click OK. The viewport may be generated without the Clip Cube at first, but hitting the Update button in the OIP will set you right. You can edit the Clip Cube by double-clicking the Viewport and editing a Design Layer. Edited July 5, 2023 by Jesse Cogswell 4 Quote Link to comment
fuberator Posted July 11, 2023 Author Share Posted July 11, 2023 amazing, I will try that out Thank you Quote Link to comment
