Can not Create Viewport
Maryam Salehi
Hi, I have a problem with the viewport.
When I want to create a viewport in my design layer. Basically, I create a rectangle and then open the "Create Viewport" menu from the "View" dropdown menu. In the dialog box, I haven't changed anything and left the default settings, then I hit "OK". Usually, after I hit "OK", it goes to the sheet layer and the viewport is there. But this time, when I hit "OK", nothing changes and it doesn't go to the sheet layer.
2 answers to this question
If your class options are set to display 'active only', and you create your viewport, the viewport will be created in the None class, but you may not be able to see it if None is not the active class, hence it will appear to you as if nothing has happened.
When I tried this, I could still see an orange bounding box, so it doesn't completely explain your problem.
