Dcrb Posted May 17, 2023 Share Posted May 17, 2023 When I opened up vw this morning render works options have disappeared from the drop down menu, including realistic colours white which I need to use. It only shows the things like wireframe, shaded and hidden line etc. This is the case in viewports or in the design layer. I have been using realistic colours white and other render option perfectly fine until this morning when they suddenly have disappeared. I have a deadline tomorrow and not know what to do. I'm using vectorworks 2023, educational version, architecture settings. Quote Link to comment
Pat Stanford Posted May 17, 2023 Share Posted May 17, 2023 Go to Vectorworks Preferences,Session Pane and click the Serial Numbers button. Does it say that Renderworsk is an Enabled Product? If so, then restart the computer. If not, then make sure you know your full serial number, click the Remove button to delete your serial number and then re-add it. Quote Link to comment
shorter Posted May 17, 2023 Share Posted May 17, 2023 and make sure you are in a standard out of the box workspace, like 'Architect' and not a custom workspace. Quote Link to comment
