JonKoch Posted May 10, 2023 Share Posted May 10, 2023 I've attached a couple of screenshots of what I'm talking about. I have a patio that has a natural edge and so I drew an aligned pad around it because I need to "warp" the patio so to speak. I can't just make a pad and apply one slope to it. As a result I get these lines that interrupt the stone pattern when I am in a 3D view. Is this to do with the way that I've edited the grading for the site modifier or is there a way to get this to stop happening? I've also shown the 2D version to show how I've graded the pad around the actual patio itself. Thanks! Quote Link to comment
Vectorworks, Inc Employee Katarina Ollikainen Posted May 10, 2023 Vectorworks, Inc Employee Share Posted May 10, 2023 @JonKoch - is this a draped hardscape? If so, can you please post the file so I can look at it. Quote Link to comment
JonKoch Posted May 10, 2023 Author Share Posted May 10, 2023 @Katarina Ollikainen It is indeed a draped hardscape. I've attached the file here. Thank you! Test.vwx Quote Link to comment
Jeff Prince Posted May 11, 2023 Share Posted May 11, 2023 I've seen this kind of behavior before, usually has to do with your texture mapping settings. Although, a lot has changed in Hardscape recently, so it could be a bug too. Here's a technique to try. 1 Quote Link to comment
JonKoch Posted May 11, 2023 Author Share Posted May 11, 2023 35 minutes ago, jeff prince said: I've seen this kind of behavior before, usually has to do with your texture mapping settings. Although, a lot has changed in Hardscape recently, so it could be a bug too. Here's a technique to try. @jeff princeJust when I thought you couldn't surprise me again, you've done it. I went in the OIP and under the render tab I just changed the mode to "by component" and it solved the issue. That's two drawings that this worked for! 2 Quote Link to comment
