Help Achieving Wall Height
CW2020
You are using Story Bound walls in a file that does not have Stories set up.  Use the Fixed Height walls instead.
If you want to fix the existing walls, you have both the Top Bound and Bottom Bound set to Layer Elevation.  Set the Top Bound to the Layer Wall Elevation and edit the Layer to have a Wall Elevation.
Then edit the components of the wall so they are not associated with the Stories.
But better to just change to a Fixed Height wall instead.
  • Like 2
I always use Story/Level bound Walls and Components.
And I am always frustrated when I copy these in a new empty file
from scratch for posting here for error checking and the Walls appear
just as flat 2D Rectangle in 3D.
Story and Level Settings should just copy over like Classes or RW Textures ....
Thank god, since VW 2016 ? or so we can just overwrite Wall tops and bottoms
in OIP easily.
Edited by zoomer
  • 2 weeks later...
