wscooper Posted April 9, 2023 Share Posted April 9, 2023 Is it possible to set the height of a ground stacked speaker. I know you can put it on a stand and then set the height, but for example on installs setting the speakers height without a stand is required. I can also see this as helpful if you were stacking speakers on top of subs? Cheers, Will Quote Link to comment
Vectorworks, Inc Employee klinzey Posted April 10, 2023 Vectorworks, Inc Employee Share Posted April 10, 2023 Yes, You just need to set the Z height of the bumper once the stack is placed. You should also be able to build your subs into ground stacked array. If you are just placing speakers you can do the same with the speaker, adjust the Z height in the OIP after you place the speaker. 1 Quote Link to comment
wscooper Posted April 10, 2023 Author Share Posted April 10, 2023 Thanks @klinzey. I'll get you a screenshot but when I added a z value the symbol didn't move in 3d space. Quote Link to comment
C. Andrew Dunning Posted April 10, 2023 Share Posted April 10, 2023 @wscooper... 1 Quote Link to comment
wscooper Posted April 11, 2023 Author Share Posted April 11, 2023 (edited) @C. Andrew Dunning Perfect thankyou! It was all working as expected it turns out, total user error! Really helpful illustration though, I feel a guidebook would be helpful that has examples like the above as part of the manuals Edited April 11, 2023 by wscooper Quote Link to comment
C. Andrew Dunning Posted April 11, 2023 Share Posted April 11, 2023 5 hours ago, wscooper said: I feel a guidebook would be helpful that has examples like the above as part of the manuals While it doesn't contain examples like you suggest, you might find the PDF manual on this page: https://www.landrudesign.com/AudioToolSet.htm to be helpful - especially, regarding the detailed info on the Library and Symbol conventions. 1 Quote Link to comment
