Exporting Worksheet columns to csv
I think the only way you are going to the able to export only the first two columns would be to make another worksheet that only has those two columns.
It might be easier to export the entire worksheet to another program and then drop the unwanted data from there.
Or a script could collect the data an write a CSV file, but the stock exports will not.
Thank You Pat,
yes I am using two worksheets already.
Background to this is that I have (similar to BIM) indexed objects in my drawings that can be exported to my rental software.
In the end I am defining packing lists for jobs already in Vectorworks and export these directly to my rental software, instead of printing the list and retyping it to the rental software.
The export sheet consists only of integer values that can be read by my rental software, but I also need a general worksheet for reviewing what I am doing before exporting.
So in the end, when I want to export 10 packing listst I need to generate 20 Worksheets, or, I genrate one export worksheet and one reviewing worksheet and edit the ctitereia 20 times. Both ways work fine, but I have to repeat this several times per day.
Exporting to an intermediate software is also possible but this will not reduce the workflow steps.
A script seems to be the only way, but my scripting skills are too weak for this.
I saw that there are marionette worksheet nodes available, so maybe it is possible to build a marionette that changes the criteria of the export worksheet and the reviewing worksheet simultaniously. I'll carry on researching on this. 😉
Edited by halfcoupler
Here is a preliminary proof of concept. The following script will export the selected area of the worksheet to a user selected/created text file using commas to separate the column data and carriage returns to separate the rows. A standard CSV file.
It does not currently handle database subrows, but it probably could be modified to do so.
It also displays the data written to the file in a VW Message box so you can review it without having to open the file. If you don't like the message then just delete the Message line (or comment is out buy surrounding it in parentheses {}) near the bottom of the script.
See how the works for your needs and use it to help define exactly what you need and we can generate a custom version for your export needs.
Procedure CSVFromWorksheetSelection;
{©2023  Pat Stanford - pat@coviana.com}
{licensed under the Boost Software License 1.0}
{https://github.com/boostorg/boost/blob/master/LICENSE_1_0.txt}
{TL/DR Use as you want, attribution for source, No warranty}
{Preliminary version proof of concept}
{April 7, 2023}
{Does not handle Worksheet Database Subrows.}
{Exports the worksheet selection to a user specified text file}
{using commas as the delimiter between column data.}
{for users who need a different delimiter, change the value in }
{the DL definition in the const section of the code to the proper character.}
CONST	DL=',';
		CR=CHR(13);
VAR	H1					:Handle;
	CCellRow,CCellCol	:Integer;
	TRow,BRow,LCol,RCol	:Integer;
	TSubRow, BSubRow	:Integer;
	RowCount, ColCount	:Integer;
	S1, CellStr			:DynArray of Char;
	FName				:String;
BEGIN
	PutFile('Choose or create file for export','MyVWCSVExport',FName);
	S1:='';
	H1:=GetTopVisibleWS;
	GetWSSelection(H1,CCellRow,CCellCol,TRow,LCol,TSubrow,BRow,RCol, BSubRow);
	For RowCount:= TRow to BRow DO
		BEGIN
			For ColCount:=LCol to RCol DO
				BEGIN
					GetWSCellStringN(H1, RowCount, ColCount,CellStr);
					S1:=Concat(S1,CellStr);
					If ColCount<>RCol Then S1:=Concat(S1,DL);
				End;
			S1:=Concat(S1,CR);
		End;
	Message(S1);
	Open(FName);
	Write(S1);
	Close(FName);
End;
Run(CSVFromWorksheetSelection);
Hi Pat,
thank you so much! Sadly I only have databased worksheets that evaluate record format data. So I only get the first line of the worksheet.
Maybe it is possible to replace the loop
        BEGIN
                BEGIN
                End;
with simply 100 rows ? 😉
OK.  Here is another version that might be closer to your needs.
It exports the data in columns A and B or the first Database in a worksheet to a CSV file.
Procedure CSVFromWorksheetFirstDB;
{April 7, 2023}
{Exports the first two columns of the first database in a worksheet as}
{a CSV file.}
CONST	DL=',';
		CR=CHR(13);
VAR	H1					:Handle;
	TSubRow, SubRowNum	:Integer;
	SRowCount			:Integer;
	NumRows, NumCols	:Integer;
	S1, CellStr1, CellStr2			:DynArray of Char;
	FName				:String;
	DBFound				:Boolean;
BEGIN
	S1:='';
	DBFound:=False;
{	GetWSSelection(H1,CCellRow,CCellCol,TRow,LCol,TSubrow,BRow,RCol, BSubRow);}
	GetWSRowColumnCount(H1,NumRows,NumCols);
	For RowCount:= 1 to NumRows DO
		BEGIN
			If ((IsWSDatabaseRow(H1,RowCount)) & (Not(DBFound))) THEN
				BEGIN
					DBFound:=True;
					GetWSSubrowCount(H1,RowCount,SubRowNum);
					For SRowCount:= 1 to SubRowNum DO
						BEGIN
							GetWSSubrowCellStrN(H1,RowCount,1,SRowCount, CellStr1);
							GetWSSubrowCellStrN(H1,RowCount,2,SRowCount, CellStr2);
							S1:=Concat(S1,CellStr1,DL,CellStr2,CR);
						End;
				End;
		End;
	Message(S1);
	Open(FName);
	Write(S1);
	Close(FName);
End;
Run(CSVFromWorksheetFirstDB);
Yes, thats hardcoding the Worksheet Name, but I want something like:
VAR:
ExportFilename : String
BEGIN
ExportFilename := GetTopVisibleWSName
PutFile('Choose or create file for export', ExportFileName, FName);
But I don't know the correct expression for "GetTopVisibleWSName"
