Jiajing Posted April 1, 2023 Share Posted April 1, 2023 Have following code to get object's coordinate on sheet layer. import vs def todo(h): p = vs.GetBBox(h) vs.AlrtDialog(p[0][0]) vs.AlrtDialog(p[0][1]) vs.ForEachObjectInLayer(todo,2,0,3) It works fine on most files until this one. It is the same code, but as shown on screenshot, instead of return -1", p[0][0] returns 377210.178727 Did I misunderstand how GETBBOX works. Quote Link to comment
Pat Stanford Posted April 1, 2023 Share Posted April 1, 2023 Are you sure that the selected object is the one the data is being returned for? For Each Object will run todo once for every object in the layer. If you want to specify the selected object, use vs.FSActLayer. Also, the last option of 3 for FEOIL is not defined in the function reference. It MAY be giving you the combination of 1 & 2 so All Layers and Selected Layers. And be very careful with Selection state. There can be things selected that you can not see. Such as in Symbol Definitions, groups, other layers. You can have selected objects that don't show up in the OIP. 1 Quote Link to comment
MullinRJ Posted April 1, 2023 Share Posted April 1, 2023 @Jiajing, I can confirm that @Pat Stanford is correct, in that the options for all of the FEOIL commands can be added together to give you combined attributes. In this case your Layer Options = 3 does in fact mean All Layers AND Visible Layers, which reduces to All Layers. Often, I'll use 3 in the Object Options to get me Visible AND Selected objects. It is possible to make ForEachObjectInLayer() act like FSActLayer if you return True from your "todo" function. When True is returned, processing stops. Returning nothing defaults to False, and all objects within the scope of the command get processed. Here's a variation of your script that shows all of the pertinent information in one Alert Dialog, including the object type number. I would recommend changing the last option to a 4, to only work on Editable layers. This avoids grabbing objects on Gray or Hidden layers. import vs CR = chr(13) # Carriage Return char def todo(h): p = vs.GetBBox(h) vs.AlrtDialog('BBox for Obj Type: ', vs.GetTypeN(h), CR, 'TL: ', p[0][0], ', ', p[0][1], CR, 'BR: ', p[1][0], ', ', p[1][1]) return True vs.ForEachObjectInLayer(todo,2,0,3) # Selected, Shallow, All & Visible layers And here's a simpler version of the same script, using vs.FSActLayer() (as Pat recommended.) This style of script is primarily used when you are working only on the Active Layer. import vs CR = chr(13) # Carriage Return char h = vs.FSActLayer() p = vs.GetBBox(h) vs.AlrtDialog('BBox for Obj Type: ', vs.GetTypeN(h), CR, 'TL: ', p[0][0], ', ', p[0][1], CR, 'BR: ', p[1][0], ', ', p[1][1]) Note: I always place a comment after the FEOIL commands to spell out the numeric meanings of the options. Unless your memory is perfect, this will save you tons of time in the future when you revisit your scripts so you don't have to relook up the command to find out what the numbers mean — again. HTH, Raymond 1 Quote Link to comment
Jiajing Posted April 24, 2023 Author Share Posted April 24, 2023 Thanks for the info. I will take a look. Quote Link to comment
Jiajing Posted April 30, 2023 Author Share Posted April 30, 2023 (edited) On 4/1/2023 at 5:11 AM, MullinRJ said: @Jiajing, I can confirm that @Pat Stanford is correct, in that the options for all of the FEOIL commands can be added together to give you combined attributes. In this case your Layer Options = 3 does in fact mean All Layers AND Visible Layers, which reduces to All Layers. Often, I'll use 3 in the Object Options to get me Visible AND Selected objects. It is possible to make ForEachObjectInLayer() act like FSActLayer if you return True from your "todo" function. When True is returned, processing stops. Returning nothing defaults to False, and all objects within the scope of the command get processed. Here's a variation of your script that shows all of the pertinent information in one Alert Dialog, including the object type number. I would recommend changing the last option to a 4, to only work on Editable layers. This avoids grabbing objects on Gray or Hidden layers. import vs CR = chr(13) # Carriage Return char def todo(h): p = vs.GetBBox(h) vs.AlrtDialog('BBox for Obj Type: ', vs.GetTypeN(h), CR, 'TL: ', p[0][0], ', ', p[0][1], CR, 'BR: ', p[1][0], ', ', p[1][1]) return True vs.ForEachObjectInLayer(todo,2,0,3) # Selected, Shallow, All & Visible layers And here's a simpler version of the same script, using vs.FSActLayer() (as Pat recommended.) This style of script is primarily used when you are working only on the Active Layer. import vs CR = chr(13) # Carriage Return char h = vs.FSActLayer() p = vs.GetBBox(h) vs.AlrtDialog('BBox for Obj Type: ', vs.GetTypeN(h), CR, 'TL: ', p[0][0], ', ', p[0][1], CR, 'BR: ', p[1][0], ', ', p[1][1]) Note: I always place a comment after the FEOIL commands to spell out the numeric meanings of the options. Unless your memory is perfect, this will save you tons of time in the future when you revisit your scripts so you don't have to relook up the command to find out what the numbers mean — again. HTH, Raymond Thank you, @Raymond and @Pat Stanford I agree that there maight be other element is selected which is not visible on OIP. I clean the file almost entirely, would love to get more details on this specifc case Attached is the file. * On sheet Layer, titled as LX-7, there is a bit map, which locates at X: 0 and Y:0 on top left. I select the bitmap and run the script Q1: If there is other element which is selected but invisble, is it suppose to be more than one AlrtDia to display all items? In this case, I only get one alert window, and TL is not 0,0 for some reason. Q2: I also check the appendex, GETTYPEN gives index of 14, which indicates it is a bitmap, but I am not sure if bounding box is giving the right info of selected bitmap. And I only have one bitmap on this document. I am with you all, but just trying to figure out what's the hidden item and how to get the right boudnbox of selected bit map Thank you 2010025715_TestFile.vwx Edited April 30, 2023 by Jiajing Quote Link to comment
Pat Stanford Posted April 30, 2023 Share Posted April 30, 2023 It is not operating the way I expected. But I think your Return True is messing up your function and causing it to only operate once. Make a group on the same layer and leave an object in it selected. Try and run the script with only the bitmap selected but with different option for ForEachObjectInLayer. I find that with the Return True, I only get the first object. If I remove the Return and set the FEOIL to be All Objects or All Visible Objects I get multiple Alerts. But the Traverse options don't seem to work. Unless the Group itself ends up as part of the returned objects, the objects contained in the group are not processed. @Sam Jones can you comment on your experience with non-visible selected objects? Quote Link to comment
Letti R Posted May 1, 2023 Share Posted May 1, 2023 (edited) Hello, when you reset the user origin, you will get the right coordinates. If you want to keep the user origin it seems like you can do something like this: import vs CR = chr(13) # Carriage Return char def todo(h): tl, br = vs.GetBBox(h) # Unpacking return values o = vs.GetOrigin() # Coordinates of user origin tl_o = (tl[0] + o[0], tl[1] + o[1]) br_o = (br[0] + o[0], br[1] + o[1]) vs.AlrtDialog('BBox for Obj Type: ', vs.GetTypeN(h), CR, 'TL: ', str(tl_o), CR, 'BR: ', str(br_o)) return True vs.ForEachObjectInLayer(todo,2,0,4) # Selected, Shallow, All & Visible layers Regards, Letti Edited May 1, 2023 by Letti R 1 Quote Link to comment
MullinRJ Posted May 1, 2023 Share Posted May 1, 2023 @Letti R beat me to the crux of the answer. There is a caveat for using GetBBox. You need to adjust for the User Origin offset when on a Sheet Layer or inside a Symbol. When you are on Design Layers, you do not need to make the adjustment. So, you need to test for your location before calling GetBBox. Also, if you definitely only want to measure the FIRST SELECTED OBJECT, then leave your return value as "True", as it will stop after processing the first selected object. Raymond 1 Quote Link to comment
