I've spent two or three hours today trying to work out which settings were making windows on a horizontal section display incorrectly.
On the left is OK, on the right, lines which should be thin elevation lines are showing as thick cut-plane lines.
Eventually I seem to have worked out that if, under "Jamb and Sash" settings, I change the "sash width offset" to something other than zero, this is the cause.
Unless there's something I'm missing I think this must be a bug.
line-weight
Example file attached below.
SWO.vwx
6 answers to this question
