Can you snap a 3D plant symbol to the surface of a 3D Polygon?
BJRobinson
When you said 3D poly as mock up, I was expecting something simpler. 😉
Try this.  Command location are from the default Designer workspace.
Duplicate the poly, select it and AEC:Terrain:Site Model from Source Data.  You should now have a Digital Terrain Model that is bigger than your original poly.
Duplicate the poly again and select it. AEC:Create Objects from Shapes. Make a Site Modifier. In the OIP set it to be a texture bed and to edit the Existing property of the DTM.
You should now be able to see your planting area (texture bed) and snap your plants to it.
Now we just wait for the real landscape guys to correct me and tell us a better way to do it. 😉
