Mathijs van Ommen Posted February 1, 2023 Share Posted February 1, 2023 Hi, Is it possible to have a vertical truss connected to another truss structure with one hoist? When I use the braceworks check the message 'The static system is not properly supported' shows. Or can I make a custom truss part to make this work? Quote Link to comment
Vectorworks, Inc Employee jcogdell Posted February 3, 2023 Vectorworks, Inc Employee Share Posted February 3, 2023 This is a hard coded safety restriction in Braceworks, The easiest workaround is to attach a point load object to the prerig truss your vertical truss is going to hang from and use that instead of the hoist and vertical truss in your calculation. Another option is to add a T corner to the top of vertical truss so you can attach a second hoist or drop to support it Quote Link to comment
AStein Posted February 2, 2024 Share Posted February 2, 2024 Is this on a list to ever get fixed? I've got torms in almost every show I do and I can't throw off my truss and hoist counts wrestling with workarounds. Quote Link to comment
