halfcoupler Posted December 11, 2022 Share Posted December 11, 2022 just stumbled over this: I wanted to create an "overview masterplan" with several referenced viewports. The refeference files have millimetres as units. The masterplan should have meters as units. Problem: Referenced vieports do not accept the unit setting of the masterplan and keep their original unit setting. Is that right or did I just oversee something ? May be I'm doing it the completely wrong way ? Or is there a work around ? Or is it not possible at all ? All files VW 2023 Quote Link to comment
halfcoupler Posted December 19, 2022 Author Share Posted December 19, 2022 hm, no one ever had a similar problem ? Meanwhile, I changed the units of all referenced files to meters, created the paperwork I needed, and switched back to milimeters. Not a very convincing workflow... Quote Link to comment
bcd Posted December 19, 2022 Share Posted December 19, 2022 (edited) A file can have only 2 units of measurements irrespective of the units in the source file : the Primary & Secondary units which are defined via File>Document Settings>Units. You can draw dimensions with either or both the Primary & Secondary units. If your referenced file already has dimensions they will appear identically in the master file. This is what I think you're referring to and is the normal behaviour. An alternative workflow would be to reference the Layers into the Master file via a (depreciated) Layer Link. The dimensions will then update to reflect the units in the Master. Edited December 19, 2022 by bcd Quote Link to comment
halfcoupler Posted December 20, 2022 Author Share Posted December 20, 2022 Hi @ bcd, thank you for this answer. That's great, and it works! I totaly forgot about the "old fashioned" way of referencing. Seems to be precisely what I need, although importing in this way imports the classes of the referenced files too, which I wanted to avoid, but you can't have everythig. 🙂 Quote Link to comment
