Wall component join at corner - can it be curved on the lower part?
rmorris6
How would a Vectorworks pro deal with this ?  I'd like to represent this architectural feature in a 3D visual. It's not imperative and I can just photoshop/fudge it, just wondered if anyone knows how to curve a wall component which joins at a corner?
Thanks in advance if anyone can advise.
1 answer to this question
You could do this with a Wall Hole Cutter symbol inserted in the Wall (or rather inserted into both Walls as the corner is formed by two Walls meeting). See:
The way to do it would be to set the top of your Wall Hole geometry at Z=0 then when you insert it in the Wall, set the height of the symbol in the OIP at the height you want the corner to transition from rounded to square.
