rmorris6
20 -
Calendar
Everything posted by rmorris6
Worksheets for drawing keys/legends causing laggy drawing
rmorris6 posted a question in Troubleshooting
Hi all, Wonder if anyone is experiencing the same. I've just spent a while learning worksheets and linking reports & text to improve workflow and save time. Now I've got the hang of it I'm finding that you have to wait every time you change something in the worksheet, like the scale or rotation of the image. Is there a way around this? Thanks. -
Record Formats box obscured, is this a bug in 2022?
rmorris6 replied to rmorris6's question in Troubleshooting
Ah ha! Thank you for responding, feeling rather silly 😉 -
Hi there, Is this a bug or something easily fixed?! Only just learning about worksheets, records etc. but this doesn't seem right. I'm using Windows 10.
Disabled WC Door (Doc M, ADA)
rmorris6 replied to Asemblance's question in Wishlist - Feature and Content Requests
Thanks so much Tom W, that's a great help. -
Thanks Tom W - kind of you to share your own 3D files - that would be great, if you don't mind. Assemblance, I'm also thinking something like what you're describing would be a revelation! I think it will just have to be a set of symbols that I spend a day putting together myself and keep in a Doc M file. -
UK Regulation compliant Symbols
rmorris6 posted a question in Wishlist - Feature and Content Requests
Could there be symbols specific to UK Building Regs, for example for a Doc M compliant WC layout and specifically door furniture? -
This would be such a useful symbol - finding the door furniture available pretty limited, and it's time consuming to draw up compliant WCs. If anyone knows the fastest way to do this or any plug in to help that would be great. A lot of Vectorworks symbols seem to be for the American market - wonder if there are plans to offer updates for UK based architects and designers, separate to the American versions, since we have different regulations to comply with? -
Hi, Don't know where to report this but it seems there is a but with 2020 - I've gone through the same process twice now and both times resulted in Vectorworks crashing. Here's the sequence: 1. Open Design Layer tab in Organization window 2. Edit proposed layer to add "Op 1" at the end (using new edit in live window feature) 3. Duplicate layer and edit "Op 1" to read "Op 2" 4. All fine but when I try to move Op1 above Op2 so that they are listed chronologically, both names change to say "Op 2" at the end. 5. Tried to change one of the same titles back to Op1 but window pops up saying "name already in use" even though they are both displaying as "Op2" 6. Click on 'Cancel' - Vectorworks disappears. I'll try to find a way around it but want to report it so if it's a bug it can be fixed. Thanks.
Issues with Active Document / Window Selection
rmorris6 replied to elarsonld's question in Known Issues
This appears to still be an issue with 2020? I had it with 2019 as well. (Signature updated) -
THis appears to still be an issue with 2020? I had it with 2019 as well. -
I was working from a file saved in the cloud and it has crashed twice so I've saved to the desktop and working from there - is it not recommended to work from a file on the cloud or is this just a glitch today?
Ps. Clip cube is something I'll have a look at next as not sure I've used this yet...!
Thank you Gadzooks and David for your helpful responses. Gadzooks, is the term 'class action' a thing? I'm still learning a few things and have been teaching myself so there could be some gaps in my Vectorworks knowledge. David S, I can never seem to get the camera to take the perfect shot without backing out of the room and seeing the backs of walls, which is how I ended up putting the wall which was in the way on a different design layer, only to be turned on in other viewports. I like your new Ikea mirror though 😊 understand you have to have lights on to get a reflection? But still if there's nothing to reflect it won't look so mirror like.... Thanks again both
So I'm drawing a small bathroom and to get a good perspective of 2 walls and floor I've removed the wall to the left. BUT there is a mirror on one of the walls and it would, inreality reflect the wall opposite which I have removed - then you would see a heated towel rail on the removed wall and the texture of that wall. It would be a great way to show the full design. But of course because I had to remove that wall to be able to see into the room, these features are not there. I was thinking that it would be brilliant if you could select in the mirror texture which classes should be turned on - so I could put wall and towel rail on classes which are turned off in the main view but not in the mirror. Does anyone know if there is already a way to do this, or has anyone had a similar issue which they have overcome in another way? Thanks in advance for all responses! Rachel Vectorworks Architect 2018 - Windows 10 PC - Intel Core i7 7820X s2066 - 3XS 8GB NVID QUADRO P4000
I know this is an old discussion, but wanted to add a request for something which would be amazing! Or maybe there is a way to do this already which I don't know, which would be even more amazing! So I'm drawing a small bathroom and to get a good perspective of 2 walls and floor I've removed the wall to the left. BUT there is a mirror on one of the walls and it would, inreality reflect the wall opposite which I have removed - then you would see a heated towel rail on the removed wall and the texture of that wall. It would be a great way to show the full design. But of course because I had to remove that wall to be able to see into the room, these features are not there. I was thinking that it would be brilliant if you could select in the mirror texture which classes should be turned on - so I could put wall and towel rail on classes which are turned off in the main view but not in the mirror. Does anyone know if there is already a way to do this, or has anyone had a similar issue which they have overcome in another way?
Best Laptop for full Renderworks capability
rmorris6 replied to rmorris6's topic in General Discussion
Thank you JimW this is incredibly helpful! -
Hi, I currently own a Dell XPS 9560 (about 4or5 years old) and it's been really good for 2D work on Vectorworks but gets very slow after importing 3D Sketchup files, so slow it's really unworkable. I saw a post on here suggesting waiting for i9chips is best and found that Dell are bringing out a new XPS with i9core in the next couple of weeks. But also noticed on the same thread that someone said XPS is underpowered. I'm not particularly tech-minded so I'm not sure, does this mean the new version will still struggle with 3D & Sketchup imports to VWX? Am I better off getting a Macbook Pro, as most Vectorworks users still seem to use Macs, but it also seems PCs are better 'gaming' computers which lend themselves to rendering capabilities much better. I must admit I'm confused! Also the graphics card recommendation from Vectorworks is that it should be less than 3 years' old. Is there any way of upgrading the laptop I currently own? Thanks in advance for any advice.
