ArrigoB Posted November 15, 2022 Share Posted November 15, 2022 Hello, I just recently switched over to Marionette from Grasshopper. This is probably really easy but im having troubles with it. How can I get the 2D area of a polygon and display is as a text in m2? I think im on the right path with the "Get 2D Area" but I don't know how to convert that info to a text symbol. Thanks in advance for the help. Arrigo Burgener Quote Link to comment
Pat Stanford Posted November 15, 2022 Share Posted November 15, 2022 Try using the STR node to convert the number returned by Get 2D Area into a string that the Text node can handle. You may have to add the unit marks "manually" as I don't know if a data type of nArea carries unit information or not. And depending on the units setting of your drawing you may need to do the math to convert to Square Meters before you convert to a string. 1 Quote Link to comment
DomC Posted November 15, 2022 Share Posted November 15, 2022 The Text Node converts the input in a string. That should not be the issue. Try the following: 1. The Text is place by coord (0,0) you should found your text oject there. Get 2D Center or BBox Center to place your text in the middle of the poly and intert the resulting point into the text Node 2. Try to connect a prefix. Even if you do not have an area it should return the prefix There is a great DataTag Tool, that would tag your polys automatically with an area. Maybe there is no script necessary. 2 Quote Link to comment
m.graf Posted November 16, 2022 Share Posted November 16, 2022 try the node "get area" - in this way... "get 2d area" is old and not good... greatings M. Graf Area.vwx 4 Quote Link to comment
