Problem with Schematic Views
Mason2152
I have been trying to use Schematic View (I am using VW 2022 Spotlight). I put in a vertical lighting pipe. I add fixtures. I then make a schematic view of the pipe and it shows how it should with the instruments (I select top view). The problem is that when I move the instruments in either view (schematic or the actual pipe) the other does not change at all (it doesn't change if I update either).
I also cannot convert the pipe to a hang position if I'm using schematic view, it either doesn't show if I make it a hang position first, or if I create a schematic view first and then convert the pipe the program crashes.
Any ideas?
1 answer to this question
