Update working file to new template
NArchitecture
Hi, we looked at similar process but in the end we set up using a saved setting in the eyedropper tool to copy and paste viewport properties/ visibilities etc, so we copy 'looks' from a library file. [That method could also copy specific layer visibilities, but we have all projects with a unique job number as part of every design layer name so that bit didn't work for us.]
  • 2 years later...
3 hours ago, MMGD said:
Otherwise I guess pasting layers from project file into the new template style is what's needed....
That's the cleanest way.
But if you use a Story/Level System - this will not transfer.
That may cause problems if you use PIO Styles relying on Levels.
Also transferring Sheet Layer Viewports may not be lossless.
With both files open, in Resource Manager you can easily import any resources like PIO Styles, Renderworks Stiles, Backgrounds, Symbols, .... easily. You can import Classes or Layers from another file viaNavigation Palette. Objects via Cut and Paste in Place. VW and Tool Settings are stored in User Folder, file independent.
And there is a work around for Story/Levels import by a Marionette.
So it depends on what data/info is needed from your template file if it makes mores sense to import your current file into a blank file from template or vice versa.
