I have been running into an issue with the overhead door's dashed overhead line depth matching the height of the door as set in the object parameters.
We would like to be able to manually change, via input or set up a standard offset beyond the height of the door to account for the actual depth an overhead door requires in a ceiling. We have found that an overhead door typically requires an additional 1'6"-2'0" of overhead clear space when you include the track arc and overrun. This has led to coordination issues in the field because in our drawing the door clearances work, however that is not accurate to reality.
Does anyone know how to edit the shape drawn by the plug-in object? Or can we add a parameter for 'clearance offset' to account for this discrepancy?
AndrewBeres
1 answer to this question
