Stan Rostas
189 -
Reputation
0 NeutralPersonal Information
Occupation
Architect-Planner
Homepage
www.shookkelley.com
Location
Charlotte, North Carolina
Recent Profile Visitors
Steve, 2.5 gb is the limit before crashing and save memory errors. Section Veiwports with Site DTM seem to effect the climb to this limit faster than without SiteDTM.
v2014 hybrid object smoothing angle not good enough
Stan Rostas replied to Christiaan's question in Wishlist - Feature and Content Requests
Christiaan, We have not seen this issue, here is a pipe turned into an Auto Hyrbrid -
Fast Interactive 3D Rendering in 2014 and the VGM
Stan Rostas replied to Dave Donley's topic in Rendering
Create a saved view with the render mode and the perspective mode saved only and you can achieve what you desire. The only issues is the saved view is not saving the cropped no crop setting at this time. Dave is incorrect though, All architects want the perspective view as the default in our office. -
Christiaan, Upgrades for our project types have worked well, but we attempt to keep all project files only a version or two back. 2014 is much better than 2013 when upgrading. -
Christiann, The 2014 Modeling environment, what with the Clip Cube, Perspective View, New X-Ray Select in 2d and 3d and now the OpenGL environment speed the user can create 3d content very Quickly! All this along with the Design layer visibility control allows users to effectively work on only that with which they intend to impact. Having had the opportunity to use the software can attest to the significance of the improvements. If you are a user that is doing any 3d in Vectorworks this is a must have upgrade. Regards, Stan -
Control transparency of 3D polygons?
Stan Rostas replied to Christiaan's topic in General Discussion
Christiaan, The only way is to create a series of Textures that are transparency textures only that uses object color for renderworks if you need object level control. The other method is by design layer but then you have to move them to the Greyed design layer as Greyed Classes does not work. -
Do not have a box without it so did not know that is the case, guess you get textures with OpenGL when you have renderworks which seems to be odd at best. Thanks for clarifying Christiaan.
Theoretically you can do this without Renderworks, you will have to use OpenGL with Edges and Textures On, edges on. That is of course if VW does not crash upon the render.
Vincent, "This probably depends partly on the fact that the program is/has been developed for several disciplines not only architecture and partly on the fact that there are no architects involved in the actual R&D." There are many Architects working at NV within the R & D. You can see there names on the many list in this forums. They do not effect the base code but they do effect the direction and implementation of many of the tools. The issue is the Vision for the entire application is and has not been determined by an Architect. The same can be said of all the application offerings and may explain the resistance by many first to CAD and now to BIM. Of course Architects come in many flavors, just look at that which gets built around the world.
Christiaan, We to have seen the same, old work methods with new features can sometimes effect desired outcomes.
Trying to reference a worksheet from an existing file.
Stan Rostas replied to MaxStudio's topic in General Discussion
Due to Layer and Class criteria not represented across files unless the files themselves are referenced prohibits Worksheets from being referenced. The Criteria List would not have available those layers or classes. You can import and replace then change criteria in order to keep formatting similar across files. -
Point your backup at a local drive location as opposed to the server but work off the server. This should keep the backup from getting corrupt. The import design layers should work, we have used this with corrupt files before, hopefully yours are not to corrupt. You basically SOL on the sheet layers though.
Workgroup referencing and associative dimensions
Stan Rostas replied to Christiaan's topic in Architecture
You cannot associate dimensions across files via work group referencing. -
CameraMatch 2013 Plug-in Released!
Stan Rostas replied to Matt Panzer's topic in 3rd Party Services, Products and Events
This add on is well worth the money, especially if one does any work with existing conditions and buildings in context of other buildings. This add on just works and in combination with renderworks representation of designs in situ are exemplary. And no I do not get any kick back for sales, just thought others should know what they are missing. -
Use them for Elevations and Material designations all the time. They work but with a complete understanding and logical placement of the notes and legends. If you want certain keynotes to be the same spanning pages you will have to use some work arounds. General Notes work well enough. If you tie all these to the note database updates across drawings can be a snap.
