PNWPaul
    23
Reputation
8 Neutral
Personal Information
  • Location
    United States
Recent Profile Visitors
  1. Has anyone else lost their full integration to ARCGis? I have a full ARC account and it signs in properly, however the ArcGis portal no longer searches properly or will allow me to go through the pages of possible matches, it will only skip directly to the last page and then you cant go back. As well my saved favorites no longer work. This has just started happening. Would love to know if anyone has a solution to this. Thanks!
  2. I do have a paid esri account. Vectorworks will pretty much bind any arc layer using the bind command ( not the background image tool ), I typically use it for rapid feasibility site plans- so property lines are only as accurate as the service provider has created them. For topo, I use a geotiff from a state or national database, and create a contour layer in arc, publish it, and it will bind accurately to the correct location (provided your vectorworks datum code is correct to the location of the parcel). It runs very smoothly.
  3. Thanks Guys for all your help! I realized the problem I was having with the testing this method was not putting grade limits around the object, causing the site to grade into the grade object boundary. Works amazing now.
  4. I tried making a simple 50' x 40' rectangle with 2% slope one direction this way, but the grade was not uniform in the center of the rectangle and it did not grade it flat. It seems when I use the grade tool it has very limited affect away from its line even if connected. Otherwise it would be great to modify the site that way. Are you using it for anything larger than small paths or driveways ?
  5. Hi Poot, I have multi sloped connected driveways, and parking areas. I connected my grade tool to see if it would create an area to drape hardscapes on and it basically made 4 very wide ditch areas all connected. Is the grade tool something different than what I am thinking ?
  6. Hi Tasmin, Are there any good tutorials videos about using the edit site modifier option ( for alligned hardscaped) and any for the process you have described. All my designs have paving surfaces with more than one slope, and I have been having difficulty doing this efficiently in VW, but I know there is probably an easy way. Thanks
  7. I bind arcgis layers (contours) and then modify by record to elevate, then convert to 3d poly and then create site model from that. Not sure if that was what you might be trying to do ?
  8. Hi Peter, Removing that file did indeed fix the problem, and I was also given a revised file to replace it with. Thanks
  9. Hi guys, It looks like there might be a solution to this problem by removing GenerateImage.vlb plugin from the Plugins folder.
  10. Not just in NZ, I'm in the States, and my Vectorworks is entirely down. Continually crashes, or after an incredibly long loading period, a file completely freezes. Yesterday, it would crash and shut down as soon as I opened the file. Completely uni-installed and re-installed from the portal, and the exact same thing happens. I just had the most embarrassing client meeting, as I was unable to show them any work. I am running Windows 11 and have the program on two different machines; the same thing on both.
  11. Mine was a complete lock up on both machines again today. Really embarrassing for a client meeting when I could not show them any of the work. @jcogdell, Is there any way to revert to the old version? Right now it doesn't work at all. Thanks, Paul
  12. This happened to me as well; I tried on both machines I use to run it. The only solution I found was to uninstall and re-install. It still will not update the libraries. But at least I can open projects again
  13. Thanks for the recommendation Jonathan, aligned site modifiers seem to work well for this one, although I do wish it was easier to align to surrounding objects, but hopefully that will come with practice.
  14. Hi Benson, The program you need is Las Zip. Download it, and it will unzip the .laz (compressed file) into a .las (uncompressed file) for you. Vectorworks will then be able to read it.
