htranbos
29 -
Everything posted by htranbos
How to draw (lines or walls) parallel to another on the fly?
htranbos replied to MarCur's topic in General Discussion
This works for me. Thank you! -
Thanks Pat and Raymond!! In that case, I think the documentation is a bit misleading. Instead of saying FSActLayer & LSActLayer return the first and last SELECTED objects. It should say FSActLayer & LSActLayer return the first and last drawn objects in the document. Is there a function to return selected objects in order, depending on how each object is selected on screen?
Thanks so much Pat!
Hello, I have 2 rectangles in my document. According to VS Python documentation: - Function FSActLayer returns a handle to the first selected object on the active layer. - Function LSActLayer returns a handle to the last selected object on the active layer When I select the left object first and the right object second, I receive the following alerts (as shown in attached screenshot) However, when I change the order of selection, by selecting the right object first and the left object second, I still receive the same alert. Wouldn't h1 & h2 order change dynamically based on whether it is selected first or last? I hope my question makes sense. Thank you! h1 = vs.FSActLayer() h2 = vs.LSActLayer() vs.AlrtDialog(h1) vs.AlrtDialog(h2)
Hello all, I finally made it to work. In order for the above code to produce the correct result, you need to put each search criteria inside a () like below. crit_string_1 = "(SEL=TRUE) & (T=NURBSCURVE)"
@twk I tried your suggestion placing criteria strings in variables. Each method works and produced no error. However, the output is still 0 instead of 1. For this test, I only have 1 Nurbs curve object in the scene and it is selected. The output of this script should be 1 instead of 0. I don't know why I can't get it to produce the correct result. myList = [] def sel(h): myList.append(h) crit_string_1 = '"SEL=TRUE" & "T=NURBSCURVE"' vs.ForEachObject(sel, crit_string_1) vs.AlrtDialog('Number of selected objects: {}'.format(len(myList)))
Thanks @twk. I will try SEL and see if it the result is correct.
I am able to make the script run without any error message.... but the output of this code should be 1 not 0. I don't know what I did wrong. myList = [] def sel(h): myList.append(h) vs.ForEachObject(sel, "(T='NURBSCURVE') & (VSEL=TRUE)") vs.AlrtDialog('Number of selected objects: {}'.format(len(myList)))
It works if I break down the code like below: myList = [] def sel(h): myList.append(h) vs.ForEachObject(sel, "T=RECT") vs.ForEachObject(sel, "T=NURBSCURVE") vs.AlrtDialog('Number of selected objects: {}'.format(len(myList)))
Hi Pat, I tried your suggestion and got the following error message. I didn't know about the criteria builder inside VS editor. This is awesome. Thank you!!
I am making a simple python script to calculate the number of items added to a list. I have multiple rectangles and nurb curves in the scene. My script is below. According to VS:Search Criteria, multiple search criteria are created using the & operator to chain individual search criteria terms. However, I got the unsupported & operator error. Does anyone know how to perform multiple search criteria with Python script? Thanks fam! myList = [] def sel(h): myList.append(h) vs.ForEachObject(sel, "T=RECT" & "T=NURBSCURVE") vs.AlrtDialog('Number of selected objects: {}'.format(len(myList)))
@JBenghiat Finally I am able to make it to work. Below is what I did: h = vs.FSActLayer() upi = vs.GetPrefReal(152) #Calculate unit per inch preference thickness = 25.4*upi*2 #Converting mm to in (1in = 25.4mm). This statement set thickness to 2" vs.CreateShell(h, thickness)
@JBenghiat Thank you! I did not realize there is a separate forum for Python Scripting. I started to mess around with units per inch preference but haven't been able to make it to work. I will play around with it some more.
I am writing a small script to create Shell Solid for a selected object. The current Document Settings units is in decimal inch. In the below script, I want to create a shell solid at 2" thickness. However, after running the script, the shell object thickness is at .079". Is there a way to convert REAL number to the correct unit in inches? h = vs.FSActLayer() vs.CreateShell(h, 2) Thanks
@Kevin Allen Thanks Kevin. I just tried that, and it worked. It's not very intuitive but it does the job.
I have a scene setup with multiple different cameras. Is there a way to use batch render in Vectorworks to export each camera view as an image in one go? Thanks!
I cannot import from mtexture. I am using Vectorworks Fundamentals 2022 running on PC. Do you know why? Please see attached screenshot! Thanks.
Auto update texture when an image is changed
htranbos replied to htranbos's question in Troubleshooting
@Elite Exhibits Yes, I have that script already. It is super helpful. -
Wow! Thanks @Jesse Cogswell for a comprehensive response. I will give this a try. -
Is there a way to make Renderworks Texture automatically update when an old image file is override by a new image file. In some other software such as 3D Studio Max, texture maps are reference by default. This makes updating texture so much faster. I am just curious if you can do something similar in Vectorworks. Thanks,
Vectorworks keeps selecting the wrong texture. PLEASE HELP!
htranbos replied to htranbos's topic in General Discussion
@Elite Exhibits Hi Peter, apparently, if I apply texture by dragging it from the resource browser, it works every time. Only when I try to change the texture via Object Info panel, that's when the problem occurs. -
@Kevin K Thanks for your response. It's not just a file. It happens to every file I have. I will try to capture it next time it happens and share it here. It's hard to do when it happens randomly. -
@Elite Exhibits I use Obj Info to select the texture to apply.
