Landartma
344 -
Everything posted by Landartma
Object Info wont reappear in Viewer
Landartma replied to TheoTheMechanic's question in Troubleshooting
It might be as simple as restarting the program.- 1 reply
- 1
Yea just refreshed and restarted the program. Still nothing. Are there visibility settings in the resource manager? I have all resources turned on but its as if I only one selected.
I'm not sure its an issue with the folders. See the simple planting plan I'm working on. Nothing that's in the file is showing in the resource manager for that plan.
I didn't intentionally move the file. If I did how do I relink it? I located the file in VW backup but it shows nothing. I am picking up the plant files when I search plants from plant tool and picking up my lines from the line selection in the attributes pallet.
I have created many resources and saved them to my favorites file. I just opened up a file and my resources do not show up. I was just using them the other day. All resources are on so I'm guessing I toggled something off. Any ideas on what went wrong here.
I did that I'm looking to get it to update in the resource manager so I only have to do it once when I find an error. We can discuss in the next training. Thanks.
Ok that's what I thought. I'm getting nothing when I do that. I have used the function before and it took me to the particular plant grouping on the plan. I'm guessing like usual I have a setting wrong. I'm also having a separate issue with plants not being counted. But here is a shot of the page maybe you can see the issue. I will also post as a separate issue.
thats right click left column and select item correct?
I have a plan from last year I need to update prices on. Can I do it directly from the worksheet in Viewport or do I need to update on the plan itself?
I have a very simple planting which is not showing plant symbols in viewport. I checked that all class and layer options are set to visible. What's the setting I'm missing here?
I have a texture I want to edit. I could swear I have done it several times before right from the resource manager. I bring up the image right click, left click and get nothing. Am I forgetting something? I made my initial image to small and it tiling when I place it.
Sweet thanks.
My navigation pallet just started reordering my layers each time I click a layer. Its messing up my work flow because I can't keep my layers straight because they keep reordering. The layer number stays the same but it scrambles up the order. I also just realized it won't let me reorder my layers so 1 is on top and the count goes up as I scroll down.
Lock down those darn OIP and navigation tabs!
Landartma replied to Kaare Baekgaard's question in Wishlist - Feature and Content Requests
Is that why my layers in the navigation panel don't stay put. Every time I try to change layers the layers re adjust their order. It just started happening today. Its driving me nuts. Please tell me it just a setting. -
I am building a display area for a shed manufacturer and have laid out circulation and variety of shed sizes. I started taking the dimensions right off the OIP for the noted size of the buildings. The buildings on the xy axis are accurate but the ones that deviate from it show odd measurements. I'm guessing that the measure in the OIP is the xy dimension of the blue handles not the object. Is there a way besides actually dimensioning each shed or running the tape measure to click on them and get the actual dimensions of the building on the OIP? The other odd thing is that the buildings were created using the square tool then placed and rotated to fit specific offsets from fences. Once I had them rotated to fit I adjusted the size in the OIP. Now some of the buildings that are off access have not only the wrong dimensions in the OIP but also have really odd dimensions when I use the dimension tool. I'm guessing that both issues have the same answer. Is there a setting for items which are off axis.
Any ideas why my viewport is so blurred? My 3d looks great then once I open it in viewport and select Isometric it goes all blurry.
Retaining Walls
Landartma replied to Landartma's question in Wishlist - Feature and Content Requests
Just got done with a training and received food for thought on the walls. I will play with it once I have it down I will post results. My season is upon me and I'll be back in the dirt most of the time so it might be a bit. See you all soon. -
Mark you used and extrude correct? Can that be turned into a wall style? I didn't think that possible.
nVidia Quadro cards now supported by Vectorworks?
Landartma replied to Art V's topic in General Discussion
I run nvidia gx rtx 2070 super....Seems to work pretty well for me. -
I have set up a pad modifier with retaining edge. Its retaining the wrong side of the wall. How do I fip the direction. I have watched a bunch of videos on it and it must be sailing right over my head. Also If grade limits are set can they be edited? If so what's the path.
this might be over simplified but can you just draw your path to the same length as your material, create 5 extrudes then just snap them to each other?
If I understand you're trying to get the curve you want with a seem that meets up with a prefab piece of material correct and that seem does not line up with the seem of the wall?
I just went through and issue I was having with retaining walls with Vectorworker's. I'm not exactly sure it the situations are similar but check out the post below it might give you some insight...maybe completely off base but we were talking curved walls.
Retaining Walls
I think you hit the nail on the head Tom. I will need to absorb what your saying and mess with it. I have been going though my images and have several dry stack walls I intend to set up as image props and textures. I will most surely keep you all updated as I progress. I second Kevin's point. Tom you really seem to get the software...You could teach it. I'm out today doing the hands on stuff. I sincerely appreciate the help in removing the training wheels. Thank you! -
Retaining Walls
Here is the extrude I did. Pretty simple. I just created the polygon with an inverted 8ish percent slope front then 90 on the back extruded along the path. Can that extrude be turned into a wall style? As it is the extrude can't have the site wall modifier applied. I'm going to put my own stone wall image props on as a textures so I can show client varying wall styles. Can you get there from here? Next I'll try a tapered extrude.
