josue Corona
Content Count
87 -
Community Reputation
3 NeutralAbout josue Corona
Rank
Apprentice
Personal Information
Location
United States
Recent Profile Visitors
437 profile views
is it possible to add a spreadsheet to title block, but that is able to be edited with the OIP , that can allow you to add more rows. Can it also be possible to add a checkmark that can allow you to hide it whenever you do not want it to display in some sheet layers. Thank you
is there a vector script to be able to slice at a curved instead of just straight slices. for example I can make arc line on top of a 3d model and that arc line will be the slice section. thank you
Thanks Andrew , that’s what I needed .
IMG_2917.MOV Hello can anyone help me if there’s a way to make a script or if vector work can do this already . I use this to symbolize drape . Basically when you rotate it becames 3D but from the top it’s a curve line . The problem in this is I can only do straight curvy lines, I would like to make arc curvy ones . thanks
{/////////////////////////////////////////// CreateNewClass (c) 2001 Nemetschek North America. Distribute freely. Shows how to create a new class in a document. ///////////////////////////////////////////} PROCEDURE CreateNewClass; VAR newname : STRING; ch : HANDLE; BEGIN { StrDialog() displays a dialog which prompts the user to enter } { a name for the new class being created. } newname:= StrDialog('Enter name of new class:','Untitled Class'); { DidCancel detects if the user clicked the Cancel button. If the } { the user did NOT click the Cancel button, then proceed with performing } { the operations in the code block. } IF NOT DidCancel THEN BEGIN { check to see if the class name is in use } ch:= GetObject(newname); { if the class name is not in use, create the class; otherwise alert } { the user and exit the script } IF (ch = NIL) THEN NameClass(newname) ELSE AlrtDialog('Class name already exists.'); END; END; Run(CreateNewClass);
The following script can create a new class but it only give you the option to name it to fast create, i was wondering if i can add a second line in which i can decide what color fill my class to have? Thank you
Does anyone know if there is a way to center a 2d or 3d object between to two lines/points. or if someone knows a script that can do that? Thank you
Hello WhoCanDo and Larry, and yes (whocando) basically that's what I am trying to accomplish, that the object to duplicate itself, next to each other as I stretch the rectangle but it will stretch in its own increments. The size of the starting rectangle can be determine in the object info. Larry Can the grid spacing be determine if I try that alternative for now?
Hello is there script I can make that I can stretch a rectangle in increments ? it can be 2D rectangle. As for the size of the rectangle I could just type it in the object info palette? The increments would be a one way stretch. Thank you
Symbol Open GL 3D object Disappear
josue Corona replied to josue Corona's topic in General Discussion
No. I am in design layer. So I am making a 3D object (wall) after I made the wall I turn it into a symbol. So whenever I wanted to go into that symbol and edit something out of the wall . whenever I was in that symbol edit (open gl) the object will basically disappear and go somewhere else in the design layer. So my rendering open gl shape would be in top let corner and my actual object would be somewhere down in design layer invisible. But removing the Unified Views fixed it . -
Hey there Pat, Thank you for your response, but it was something different. The problems was the UNIFIED VIEW was activated . -
Hello, Does anyone know why when I make a symbol and then I try editing it, the 3d object disappears when I am in open gl mode. I am using vectorwork 2019 spotlight . Thanks
I just found out how , thank you.Theres a option called Email PDF, which just makes pdf and sends it . 😄
I have spotlight , and Mac. I do use save as a pdf, but lets say I save it as a PDF, it goes into a folder then I have to go to my email and drag the file into my email. I want to try to email it without dragging it. Like if theres a way to make it like save as PDF and email at the same time ?
Is there a way in vector work to be able create a pdf file and then be able to email it. Thanks
