Viper x
351 -
Everything posted by Viper x
The plant symbols I am using are the ones supplied in the 2d symbol folder so that is not the problem. The problem was these odd selection markers, clearly thay are something different from the norm, ie black filled versions.
Place plant symbol > from the attributes pallette apply a colour fill to the symbols, usually shades of green. I need to show the line work below, what is the best way to do this please. Thanks Note I have been trying to send the coloured plant symbols "to the back" to make the line work visible but this has no effect ? Well blow me down. I kept messing around and placed new plant symbols on the drawing and I could send them back and the line work was then visible, the ones that could not do this to had the 4 small boxes that show up when you select it with no fill, ie the ones that did work all the their boxes were solid black. What the hell is that about ? [ 10-27-2005, 09:03 AM: Message edited by: Viper x ]
Memory leaks have been a major problem for me for ages, everything suggested I have tried with little use, the same leakage now happens in VW11.5 http://techboard.nemetschek.net/cgi/ubb/ultimatebb.cgi?ubb=get_topic;f=12;t=004174 [ 07-12-2005, 06:20 PM: Message edited by: Viper x ]
Hi Robert, As far as you know has there been any problem purging in 11.5, I have a number of large drawings and I would like to limit their size but I am nervous given the problems encountered before. Thanks Viper [ 06-27-2005, 01:01 AM: Message edited by: Viper x ]
Trouble getting an imported base layer in the same location
Viper x replied to Viper x's topic in General Discussion
quote: Originally posted by CipesDesign: From where are you importing it? From an ACAD file? From another VW's file? I am importing an autocad file, which means I guess that I can not change the origin setting of the imported drawing. My drawing has "set origin to drawing center" is this how it should be ? [ 06-01-2005, 05:10 PM: Message edited by: Viper x ] -
Thanks Nick, and I take it you can not copy things from a viewport back into a design layer ?
When I am importing a new base layer I am having trouble getting it to "land" in the same location on the drawing so I can just turn the old base layer off and the new layer on and a third layer will match exactly. The new base layer is coming in to the side and I am having to turn the old layer off then select all of the third layer and drag it across to the new base layer, it is then hard to get it to line up exactly each time and I am sure this is not a clever way to achieve this. What am I doing wrong please ? [ 06-01-2005, 07:19 AM: Message edited by: Viper x ]
I am importing a Autocad DWG, when it comes in I get 2 files one as a "above the line" viewport and one in a design layer, the viewport has extra things on it like text block and title etc, whereas the design layer is without them. The file in the design layer comes in as a symbol which I have to turn into a group, then ungroup so I can work on it. Questions: 1. Is this spliting into 2 different files what I should be expecting in VW11 2. Should I expect all DWG I now import into VW11 to react in this way ? 3. I am getting 2 files because the originator has saved a design layer "and" a different viewport layer ? 4. This never happened in VW10 is this because VW10 never supported viewports, so even though my originator may have sent a design layer and a viewport layer VW1O would never have been able to display them ? Thanks for any help.
quote: Originally posted by Marietta: I have been importing on a new design layer and then using saved sheets to adjust which classes to turn off and on. This is a bit time consumong, but works oif there are a lot of classes you want to adjust (visibility, colour, line weight, etc.). Delmer, the work group referencing sounds good. How is this done? can you also save class assignments with this? Two questions : 1. I too copy the file into a new layer and then change that file quite a lot by stripping it down by turning classes off, why do you take the next step and adjust your new base in saved sheets rather than in the new design layer ? 2. I have just copied a new base into a drawing which has existing multiple layer and it seems the new base has copied into each of the existing layers, what have I done wrong ?
What is the safest and best way to slide in a modified base plan to an existing drawing ? Just import it as a new design layer?
I had a vw10 drawing that I converted to 11, all looked fine and the plants were intact. I have then copied hundreds the plants in the vw11 drawing and pasted them into another vw 11 drawing but only the tags and the small x in the middle of the symbol shows up. I know the plant symbol is made up of 2 parts and I have made sure both the none class and the class the plants are in are turned on in both drawings. What have I done wrong please ? I can copy and paste all the plants in the same drawing OK but when I try to paste them in the new VW11 drawing no symbols appear. I have no symbols even when I copy and paste into a new blank vw11 drawing [ 05-26-2005, 04:23 AM: Message edited by: Viper x ]
Thanks Paul. A question, when you run the update and it asks which version you want updated, is it the original VW 11.0.1 or is it VW 11.5.exe that needs to be updated ?
quote: Originally posted by Pharr: We feel that the Windows stability issues being experienced by some of our Windows customers are serious enough to warrant the release of an unscheduled service pack to address them. You are not alone there Pharr. Looking forward to greater stability.
I have similar problems : I am getting "NO MEMORY" and the drawing is closing down, this is happening regularly. Watching the task manager when VW is running the PF (page file) usage meter continually creeps up to as high as 1.6MG ! and when it is around this high the drawing crashes with a message "NO MEMORY" I have watched the meter with numerous other applications running and it never gets above 600mg I have all other applications closed. I am still on SP1. I have 512mg of Ram It only happens when I am running VW. I have updated the Video card [ 03-13-2005, 01:46 AM: Message edited by: Viper x ]
The "my profile" button which is found top right of this page, click on it then click on "edit profile" and then enter your detail under "Signature:" quote: my profile | directory login | register | search | faq | forum home [ 03-11-2005, 06:01 PM: Message edited by: Viper x ]
Um... sounds like a tricky one there, no help I am afraid but best of luck with it.
And I find that how ?
quote: Originally posted by den: After showing landscape tags I have been able to move them by grabbing the arrow that displays at the end of the leader. In my current design I am not given the option? I thought I was getting the hang of this, can you tell me what I'm not doing. How do you mean you are "not given the option" are the tags there, but you can not pick them up ? You have the "object info palette" switched on ? What version are you on ? It is useful to edit your profile and put all your details at the bottom of your post so we know where you are coming from. [ 03-10-2005, 01:56 AM: Message edited by: Viper x ]
Questions : 1.I am not doing anything wrong but worksheets will not scale inside a drawing in VW11 nornally is that correct ? 2. I have not worked with viewports yet, is this the only method to scale worksheets Jonathan?
I am changing the scale from 1:100 to 1:500, I have "scale all layers and text checked" and the drawing changes scale fine except the worksheet does not, it remains at the larger 1:100 size ? What is the trick please?
Seems to have gone in without a hitch, thanks Robert.
Small, 4.86mg
Why is next to nothing straight forward with CAD I know I am no expert but Loaded on the free program and printed to PDF995 and nothing happened it just hung. I followed this instruction : quote: To create a PDF file: Print a document from any application choosing the PDF995 printer from the printer dialog. Do NOT select "print to file." You will be prompted to enter the name of the PDF file you wish to create. The PDF will be automatically launched in Acrobat (pdfEdit995 may be used to configure this option). file://C:\pdf995\readme.html
I am getting "NO MEMORY" and the drawing is closing down, this is happening regularly. Watching the task manager when VW is running the PF (page file) usage meter continually creeps up to as high as 1.6MG ! and when it is around this high the drawing crashes with a message "NO MEMORY" I have watched the meter with numerous other applications running and it never gets above 600mg I have all other applications closed. I am still on SP1. I have 512mg of Ram It only happens when I am running VW. I have updated the Video card Any suggestions please ? [ 03-08-2005, 03:40 AM: Message edited by: Viper x ]
Thanks Mike I will start there. As an aside is there a basic reason why there is not a simple choice in the export function to "export as a PDF" like there is for DWG ?
