Having major problems with the above.
We have a plant database in Excel format, sadly the Filemaker runtime doesn't import Excel directly so we convert to tab delimited file. This them appears to imort to the Filemaker version of the plant reference data file (.txt format)OK. When I run the script to export ready for copying to VW the data check in filemaker runs OK. I then copy the PlantReferenceData.txt file to the VW data folder. When I run VW to view the Plant reference data I get the following error:
Warning: _351 _10 - Error in read data.
Error: _351 _10 - Array ALLOCATE end < start: _26
Does this mean anything to anyone?
If I set up a quick and dirty Excel sheet and import that it works just fine - the problem lies with importing data from a particular source - even though their sheet appears to be clean and tidy it always fails. Have tried most types of data file to import - sylk, wps etc and same result.
Help
TIA
Woodfiddley
