82 -
Reputation
40 GreatPersonal Information
Occupation
Lighting Designer
Homepage
www.photonika.life
Hobbies
Road Bike
Location
Italy
Contact Info
Skype
sbrebo
Recent Profile Visitors
1,430 profile views
Yes, I can do the same also in box, but I wanted to try using the possibility to interact directly with the web 😉
Hi to everybody. Working in a big project where all the team is connected by BOX. I use a lot of referenced file, like DWG or PDF, working opening directy the vwx file from box. The problem is that I can reference only files saved on my PC and can't flag "path relative to current document". Any workaround?
Yes, I confirm. MVR from Vectorworks to Wysiwyg works very well if you start to design in Spotlight, also merging parts of the project. I never try from Wysiwyg to Vectorworks
Walter Lutzu changed their profile photo
Skakki started following Walter Lutzu
Light beams of GDFT Fixtures in Vision 2020
Walter Lutzu replied to MarcoNJ's topic in Vision and Previsualization
Hello everybody! I've the same problem: fixture in a place and beam in another... Exported mvr from vw with gdtf mode. If I sent to vision all works well but I don't have the correct mode to set, this is why I choose mvr. see attached -
Thanks Klinzey!
yes, going to test installation on clean boot and other things. I'll keep you updated
here what I'm using Processors ------------------------------------------------------------------------- Number of sockets 1 Number of threads 12 Socket 1 ID = 0 Number of cores 6 (max 6) Number of threads 12 (max 12) Name Intel Core i7 8750H Codename Coffee Lake Specification Intel(R) Core(TM) i7-8750H CPU @ 2.20GHz Memory Type DDR4 Memory Size 32 GBytes Channels Dual Memory Frequency 1330.5 MHz (1:20) Graphics card NVIDIA Gforce GTX 1060, 6gb memory
yes is the last version sp3. I also tried to remove everything in detail and reinstal but doesn't work. Is there a log somewhere to check?
hi to everyone! anyone of you has problems updating library in vision? When I press "update library", the screen stays on "downoading update" for hours and doesn't download anything. See attached image. Thanks for your support!
Could be usefull to have a tool that allow to build a strip LED with some parameters like brand of LED, kind of LED (white, multichip etc...), size of the strip, distance between LEDs and soo on
Hi to all, I've a similar problem with Vision 2020. When I press "Update Library" it show "Downloading Update" but nothing happen. I set the windows 10 firewall correctly, run as admin, but nothing change
Spotlight instrument focus
Walter Lutzu replied to Walter Lutzu's question in Wishlist - Feature and Content Requests
Please ASAP 😄 😄 😄 -
Walter Lutzu posted a question in Wishlist - Feature and Content Requests
Could be usefull to allow the editing of focus position without the use of Focus Position Tool. Just setting the pan/tilt value of one or more fixture. For example could be usefull when I select 50 fixtures in a row and put all pan=90°, tlt 20°. Now 've to create 50 focus point and.... -
spotlight fixture request form doesn't work
Walter Lutzu replied to Walter Lutzu's question in Troubleshooting
Thanks a lot Rob! I have just sent some requests 😉 I can also provide additional documentations about the fixtures (3d cad files, specification of external power/DMX units, email address of the factory product specialists, etc...) Just tell me how to do it (on the form I can upload only one file). Thanks a lot! Walter
