445 -
Posts posted by Wesley Burrows
On 11/17/2017 at 2:46 AM, Nikolay Zhelyazkov said:
Do you have any other Title Block Borders in the file you are pasting your template TBB?
I just tried this with a different file that did indeed have an old title block
On 11/17/2017 at 2:46 AM, Nikolay Zhelyazkov said:what option are you selecting on the Merge Formats dialog?
I was prompted with no merge/replace dialog of any kind.
On 11/17/2017 at 9:36 AM, Wesley Burrows said:Could you test this in SP-2, when it is released, and let me know if you are still reproducing it?
I just did this in SP2 and the problem remains.
On 11/19/2017 at 5:43 PM, NeilB said:What happens when you import (rather than copying & pasting) the Title Block Border from the source file into your destination file via the Resource Manager?
I also just tried this in SP2 and got the same result.
If you use the truss PIO to rough in your design, (maybe you're not sure what truss you'll be using yet) but you finally solidify that and want to replace your PIO with stock symbols, great. How come when you do this, the replaced pieces of stock symbols do not auto connect as a system as they would if you redrew the whole thing via the insert truss tool? I'm using the same symbols for replace with stock symbols as I am for the insert truss symbol. It seems to me like it should auto-connect. Am I missing something? Was this intentional, overlooked, or deemed unnecessary?
Update, this bug still exists in SP2.
On 11/17/2017 at 10:39 AM, BrandonSPP said:
Snapping to the center line is fixed in SP2, I will need to test the rest but I think we solved them as well.
I tested all of the above and confirm they seem to be solved in SP2
3 minutes ago, kevn said:
1) Can we hang a projector on a prolyte like with Wysiwyg, because I have to use the HEIGHT to stick it to the prolyte?
Currently the video screen is the only device that "attaches" to a hanging position if you attached it as a load, they don't attach separately.
3 minutes ago, kevn said:2) Do you know a tutorial to understand the use of Braceworks?
I have been face first into Braceworks the last 2 weeks or so, using it on a pretty size-able show, so I can try and help. The PJ load is calculated as part of the truss it is under (hanging position or not) if it is within the Braceworks user preferences tolerances of proximity to the supporting truss. If you have the PJ lower than the threshold under the truss it will not calculate it. Because you can't attach the screen and PJ separately, in that case I just add a point load to the truss with the PJ's weight and use that for Braceworks calculations instead of the actual PJ symbol. If that helps. I haven't found much in the way of tutorials, though I was at a breakout session at Vectorworks Design Summit with the guy who created it, so, of course, that helped.
The times I've needed to do this I either done it via Cinema 4D exporting the model and replacing the screen material with video, OR rendering a still in VW replacing the screen with green and keying it out in After Effects.
It would be great to able to do that in VW, Along these lines I wish you could link a camera to a texture to have IMAG on a screen without doing a separate render for that.
6 hours ago, Nikolay Zhelyazkov said:
Hello Wesley,
Do you have any other Title Block Borders in the file you are pasting your template TBB? If so, what option are you selecting on the Merge Formats dialog? Could you test this in SP-2, when it is released, and let me know if you are still reproducing it?
Thanks,
Nikolay Zhelyazkov
I don't think so. I also got no merge/replace dialog, so that leads me to believe that I didn't. I will test in SP2. Hopefully that means SP2 is appearing soon. =)
I have a 2018 sheet border/title block design that I made in my template file. I want to use this in an existing file. When I tried copying the sheet border from my template file and pasting it in place in my existing drawing, all of the data fields are reset to default, How do I correct this? I've tried purging sheet border special records, reseting plugin objects.
Template File:
Paste from Template File:
@JimW this might get a bit more response in the Spotlight section, or perhaps Troubleshooting.
@BrandonSPPdo you know if any of the above has been addressed in the forthcoming SP2?
-W
15 hours ago, James Russell said:
Part One
- Make a truss.
- Convert to lighting position.
- Using Instrument Insertion place a few lamps onto the truss.
- Raise Truss lighting position to 6000mm in Z.
- Ensure lights stay on truss from front view.
Part One Result (with Truss PIO)
15 hours ago, James Russell said:Part Two
- Make a Truss.
- Ensure lights are hung on truss (mine aren't!)
Part Two Result (with Truss PIO)
Both ended up the same for me. (wrong, because of moving lights inside the truss) but attached. Unless you tried the fun party trick of selecting all of that position and moving it to a new design layer. Then you get this fanciness:
Or if you delete the right two fixtures from the original and mirror the left two across the center line, then you get this:
There are lots of issues with the 2018 (SP1 at the moment) hanging position. So I don't doubt you are getting strange results.
17 minutes ago, Kevin McAllister said:
This is both good news and immensely terrifying for obvious reasons. I'm sad that so many resources may go into redoing something that was just done when there are so many other things are still on the bigger list.
^My immediate thoughts.
I'm trying to do some VW cloud publishing, I managed to get it working with the default Cloud Services Folder, but when I tried Dropbox it I get this,:
The resultant PDF is like 834bytes (Blank). The VWX is sync'd in my company's dropbox folder(s) where it lives, and I also exported the file to the same folder. I have given cloud services permission for full Dropbox integration. I suspect that the way I use aliases might have something to do with it. Basically we use dropbox as a company, but the folder organization that works for the majority, sucks for me and there is too much time navigating, not enough time doing. So I do something like below:
My Company wants:
Dropbox > Current > Client > Show Name > Layouts and Renders (there are other folders, but this is only one I care about)
What I want to see:
Dropbox > Working Plots which shows a list of all the current shows by show name that points directly to the respective "Layout and Renders" folder of each. I accomplish this via some applescripting and aliases.
However when I added full dropbox integration to Vectorworks Cloud Services my dropbox then shows:
It seems to just hang while syncing remaining files, which based on the sync icons in my Working Plots directory, it has X's at all of the aliases like that's causing it, or if VW cloud services is in some sort of endless loop trying to index my dropbox account. I'm not sure. But it works fine without the integration. Do aliases break the integration? Can anyone offer any help?
14 minutes ago, Pat Stanford said:
If you really need to do it, you would do it more or less the same way you would build it.
If you are going to radius the end of the lacing, you would probably not also drill a hole in the top or bottom pipe. You would just trim the lacing and then weld them together.
In this case, just make a sacrificial solid extrusion the same diameter as the pipe without holes and use that to trim the lacing. Make sure the Retain Subtracting Object check box is unchecked unless you are going to use it to do other laces.
But perhaps a bigger question. Do you need to make this into a Solid at all? If this is going to be part of a symbol, or even a group, could you just intersect an over length lacing and not worry about the extra solids operation?
Unless you are selling truss, or are going to do extreme closeups of the truss, it is unlikely that in any rendered view that a recipient of the drawing would ever know if the lacing is over length and just hidden by being inside the pipe.
I always recommend that people not spend time modeling things that won't matter. I worked with a client who insisted on putting hanging wires on the backs of picture frames because that is how they would actually be hung. But then he did not bother to put the frame at the fractional angle that would result in real life. So he was spending time end energy modeling something to make it "real" but that would never be noticed in a rendering.
Only you can know
Thanks Pat! I thought that might be the case. Your points are all very valid. More for my curiosity I guess and problem solving. Though as you state, for 99% of people's use cases, it's likely not a problem to really bother solving.
If I were trying to model the side lacing on a truss. How would I get the selected extrude along a path to trim it's ends contoured to the top and bottom extruded circles? Or am I approaching this the wrong way?
I tried subtract solids, but it doesn't remove the end, I assume because the top and bottom pipe have a hole through them. I'm sure I'm just being an idiot. What is the smart way to do this?
1 hour ago, Andy Broomell said:
True, but then it adds a ton of bases/verticals along the longer segments. I guess I could just make that small portion a separate object with different settings. Not ideal, but good enough for now. It would be nice to add the ability to turn off the red highlighting feature in the future.
I agree a highlight toggle like that of the truss tool would be useful.
On 9/15/2017 at 5:29 PM, Andy Broomell said:
I completely agree.
Vectorworks has this nasty habit of requiring as many clicks as possible.
@JimW - Any way that Vectorworks could look into hiring a full time click reducer? There are so many tasks that require many more clicks than should be necessary. Just one example: https://forum.vectorworks.net/index.php?/topic/45348-image-props-should-auto-recognize-pngs-with-transparency/
They could be paid based on the number of clicks they reduce
This is brilliant! I would contribute to a go fund me to pay this persons salary. As someone who clicks all day, 5 (or more) days a week, (90% of the time in Vectorworks) my clicks are valuable to me, I fight with carpal tunnel regularly and there are only so many clicks I have before my clicking finger just gives up. Please don't make me spend them unnecessarily. It gets to be infuriating when my finger/hand is giving up and I'm clicking when a TAB, ENTER, ARROWS etc will do! PLEASE. I'm only half-kidding. I swear everyday I'm closing in on my clicking fingers MTBF. (I also own the most ergonomical mouse I could find, an Evoluent Vertical Mouse, and it has been a big help, but still)
I'd like to propose that when you toggle the double purchase (sidebar, I've always heard this as called double reeved when referring to motors, and double-purchase for fly rail systems, maybe it's a US thing?) option in the hoist tool the diagramed changes happen. Basically:
When the toggle is ON:
The max allowable weight of the the selected hoist doubles from it it's default capacity
The speed in feet per minute is halved (though this is't a big deal, but it might be useful)
The total chain length get's doubled from it's default or current value.
When the toggle is OFF:
The max allowable weight returns to the defined max of the selected symbol.
The speed in feet per minuted is doubled (once again, not a big deal)
The total chain length get halved from it's current value.
After inserting a bunch of 1/4T's that are double reeved (double purchased) for a ballroom show, I have to update them all the time to have their max allowable weight be 1000#'s. I've found every time I insert one it resets to the default max of 500#. Option + Dragging won't work half the time cause the motor won't attach to positions when I do it that way. The eye dropper tool also dosen't seem to want to grab the max weight as part of the plugin parameters. The tool WILL however remember the double purchase toggle, so It would be great if it could adjust the base values accordingly with it on.
After all this is how motors generally work in the real world. It would make the tool more useable especially in conjunction with Braceworks.
I am open to further thoughts/discussion. Just some observations of the tool use while diving face first into Braceworks.
- 1
6 minutes ago, markdd said:
Tech support said early November so any day now I guess.
Here's hoping!
32 minutes ago, RickR said:
Do your layers have different heights?
My habit from previous versions is always to draw lighting position symbols at Z=0. Then there is never any confusion over position height or where on the symbol the fixture lands. It seems that truss objects in the library don't follow this rule as they have 0,0 at the truss center.
No, brand new layers with no height.
On one hand Braceworks has saved me a bunch of time, on the other, I'm beating my head against the wall with some otherwise simple tasks.
On 9/23/2017 at 4:17 PM, wclights said:
So about half the time my light will associate with the z-position, but even if it does I have found if I change the design layer the instrument is on (like when I accidentally draft it into the wrong layer to begin with) it almost always resets the z-position to 0".
I am on SP1 and have run in to this too. The Z height changing when reassigning layers is driving me insane. I have had it happen with lights and video walls so far.
1 minute ago, Rob Books said:
we request from them, Moments of Inertia, Bending Moments, Shearing Force, and Tube Force.
and Yes, hopefully we will Get Tomcat and J. Thomas onboard after the meetings at LDI.
for some that are missing Data, the Manufacturer is working with us, just taking them time to get the data to us and then converted to the cross-section in Vectorworks. the nice thing is that I was able to set most of them up with an ID so that once the Cross Section is in, it will auto correct and we won't have to re-issue libraries.
For those those of us that also have some quantities of slightly less mainstream manufacturers. (Applied Electronics in my case) Where they aren't in the library at all, what would be the appropriate method to try and obtain that info?
For manufacturers that wouldn't (or just haven't) provided the truss cross-section information to be included in the Vectorworks truss library. (Ugh) What is the right information to ask for from them, on an individual request basis? I think I remember it primarily being the lxx, lyy, and lzz. But I can't remember the exact terminology. Or should I just send the screen shot and ask them to be so kind as to provide the asked info?
Edited to add: Tomcat responded to me and they aren't providing that information at this time, but their engineers have a meeting with Vectorworks after LDI. Fingers crossed :-)
Service Pack 2 for Vectorworks 2018 Released
in News You Need
Posted
It works for me, you don't by chance have the cloud de-selected in the resource browser do you?
