Jiajing
101 -
Reputation
9 NeutralPersonal Information
Location
United States
Recent Profile Visitors
1,915 profile views
any chance @JustinVH can share the file with me as well
I have filter set for classes in organization dialogue , I do not think it is actually working. It works fine on elsewhere
What I learned from @Scott C. Parker is that there is a bug on EQUIPMENT SUMMARY about COMPARE TO INVENTORY, basically it is not working, it suppose to compare to inventory list. I'm with you as well, the inventory list is stored locally, which makes it way hard to share files with team. I haven't found a good work around yet.
Objects in Hidden Line Renders are Randomly Red
Jiajing replied to garrettohler's question in Troubleshooting
The last time i had that problem was on truss, I think I fixed it by script. would you mind share your symbol ? -
Thank you, I missed that. @Tom W.
Is it possible to have multiple criterias on graphic legend as 'OR' on opposte to 'AND'. Try to have a list of LIGHT DEVICE and STATIC ACCESSORY on one graphic legend.
Thank you, Scott. Also would love to the difference between plug in of symbol VS. Symbol itself. Would it be great that just show light devise as ome kind if possible
@Scott C. Parker Attached. Inventory.vwx Shop1.xml
Need help on COMPARE TO INVENTORY of Equipment Summary. For instance, I have (1) leko with total inventory of (10). When I turn on COMPARE TO INVENTORY on Key, it shows inventory as (0). My question is: * which inventory is key referencing to Am i missing anything here
With more than 10 years working experiecne on Entertainment industry using Vectorworks, my work has been focused on production design, technicial drawing, engineer drawing and rendering. From file conversion, detailed technicial drawing, integration design to pre- visulization, those skills offers client with a complete set of drawing package before walking in to the venue. In addition to that, I will provide power calculation or rigging proposal for engineering purpose. Most of my work focuses on TV , concerts, music festival, theater, art installation and arch floorplan. That's been said, I'm seeking freelance drafting work or design engineer opportunities (open to in house work ). Please feel free to message me directly. Happy Holidays
Thank you, @Raymond and @Pat Stanford I agree that there maight be other element is selected which is not visible on OIP. I clean the file almost entirely, would love to get more details on this specifc case Attached is the file. * On sheet Layer, titled as LX-7, there is a bit map, which locates at X: 0 and Y:0 on top left. I select the bitmap and run the script Q1: If there is other element which is selected but invisble, is it suppose to be more than one AlrtDia to display all items? In this case, I only get one alert window, and TL is not 0,0 for some reason. Q2: I also check the appendex, GETTYPEN gives index of 14, which indicates it is a bitmap, but I am not sure if bounding box is giving the right info of selected bitmap. And I only have one bitmap on this document. I am with you all, but just trying to figure out what's the hidden item and how to get the right boudnbox of selected bit map Thank you 2010025715_TestFile.vwx
Thank you, Josh. That explained, after I delete symbol, the code works just fine. good to know. I can not have class named 'Astera AX5', but I can add prefix and have class named as 'LX-Asteria AX5'. That might be a work around.
Thanks for quick response. Good to know. It would be great to add this note to the NAMECLASS wiki page. On wiki page, it only mentioned 'If the specified class already exists, then it will become the active class of the document.' https://developer.vectorworks.net/index.php/VS:NameClass Thank you
Interestingly, I tried the same code on a brand new file, it works. lol
