fabrica
351 -
Everything posted by fabrica
Changing Drawing Numbers Takes too long!
fabrica replied to Tom Klaber's question in Troubleshooting
i just change in object info panel - and its instant? (quicker anyway than double clicking on viewport and waiting for it churn open....) -
2020 Teaser Tuesday - List Browser Direct Editing - Vectorworks 2020
fabrica replied to JuanP's topic in News You Need
good feature. ps. would help if you lowered the background music when someone is speaking ! pps - I wanted to see stair, window, door updates first ...... -
that would be my process - ie. build the existing (ie. survey) , save as a new drawing for new works and revise model (put survey on a layer for reference in new model)
- 5 replies
- workflow
- residential
(and 1 more)
Tagged with:
so C4D 21 is going subscription based........ and one version only .... https://www.maxon.net/en/products/cinema-4d/integration/architecture/vectorworks/
Double socket and light switch - help needed
fabrica replied to CharlottePea's topic in General Discussion
@CharlottePea you'll probably have to import them in for your 3d model , the vectorworks MEP ones are useless. https://3dwarehouse.sketchup.com/model/2c8d01bcaddfa37266147d84ed908c45/UK-Double-Socket?hl=en -
Flattening 'arial' view of 3d model into editable 2d image
fabrica replied to a topic in Architecture
Frame stops for Door Tool
fabrica replied to Christiaan's question in Wishlist - Feature and Content Requests
I like your optimism!! BUT.... it would appear that the window/door/stair tool is sub-contracted out and not made by vectorworks - users have been complaining for years about these tools but unless the suppliers update their tools nothing happens.... -
- 31 replies
- renderworks
- rendering
(and 1 more)
Tagged with:
thanks for the file - very interesting that fullscreen preview option adds quite a lot of time to the speed of render - , 28 secs without ; 38 secs with full screen preview.....
- 31 replies
- renderworks
- rendering
(and 1 more)
Tagged with:
VWs 2019 Title Block - batch Renaming/renumbering Sheets
fabrica replied to twhitwell6's question in Troubleshooting
make a worksheet of the titleblock and you can quickly change names / numbers etc , handy for changing multiple dates or stages... -
with maxon acquiring redshift (and a metal version coming), have to hope this will eventually filter down to vectorworks through cinerender? also, can't see the point of a mac pro for vectorworks? seems to be like using a ferrari to go to the local shop !!
@Mason2152 @jeff prince - sorry - you'll need to purchase from to see
or try this: https://learn.archoncad.com/blog/2011/02/28/sst_1102-creating-a-swimming-pool/
would normally add hatches/images etc in viewport annotations - make a polygon fill and change to your selected hatch/tile
I'm getting a lot of spinning ball when trying to do polygon fills in viewports with SP.3 (mojave) Also getting an occasional crash when trying to add polygons together , get this odd object info box as below and have to force quit.
you can rotate the interior elevation symbol on the plan - this will rotate the section lines
- 2 replies
- interiorelevationviewport
- dispaly2dcomponents
- (and 3 more)
UNRESPONSIVE VW - Creating/selecting framing member
fabrica replied to Pavol D.'s question in Troubleshooting
try it on a blank file with framing member = spinning ball of death.... (mac and mojave user) locks into a freeze and takes about 5 mins before I can use it (even worse on existing files) , see circled area where it seems to lag -
having the same issue with framing member , on SP3 also.... -
the offending item... F_Door.vwx
I'm trying to use a custom symbol made up of 3 others windows + a door to make custom front door.... I cannot get the walls to be correct (in plan) and I suspect I'm missing a simple trick! Elevation is correct though!
VW2019 Performing very slowly & Crashing regularly
fabrica replied to PeterF's question in Troubleshooting
yes, the spinning ball of death has returned for me also (mac) in the last week , anything that requires a detailed object info menu , (stairs, elevation benchmarks) is now causing a hang...
