gummidge
8 -
Reputation
0 NeutralPersonal Information
Location
UK
Hi CipesD - thanks that looks just the job
Hi fabrica, Thank you for the link but I am not looking for a texture (realistic) I am looking for a hatch fill.
Hi, Does anyone have a hatch for OSB board or can point me to the UK standard if it exists. Many thanks
Dimensioning 3D projections in Viewport Annotation
gummidge replied to Pedro P. Palazzo's topic in General Discussion
Im surprised after 3 years from when this thread was last added to that the ability to use dimensions in layer plane/3D in a viewport has not been introduced. It is counter intuitive not to have it and does not create an efficient workflow. Is this feature coming???? -
I have one question that is not answered in the recent thread. If the Worksheet is to be be used by various colleagues who will set up there own layers and classes, which I do not have control over, I cannot use classes or layers as part of the equation. Ive noticed that you are able to use visibility? Ive have been using the below equation to try to count an electrical symbol? but the visibility doesn't seem to be working? =COUNT((S='50w Fixed Downlighter') & (V)) Any help would be appreciated
Thanks all for your help. Took a look at the recent discussion, very helpful.
I'm trying to make a key for electrical symbols which will show the symbol, calculate the number in a drawing and give the symbol name. Ive got as far as creating a worksheet which effectively does this but without the symbol graphic showing. Is it possible to import the symbol image into the spreadsheet and match up with data? Or is there an easier way of doing all this? Any help would be appreciated. Using VW 2010 Fundamentals
I am having a little issue with grid lines which should be quite simple but seems to have no obvious solution. In VW Fundamentals 2010 when I create a new document I automatically get grid lines on the first layer. How do I turn this off. In VW Architect there is an option under file - document settings but the option doesn't seem to be available in Fundamentals? Is there an alternative way? Second.. both myself (running VW Fundamentals 2010) and a colleague (running VW Architect 2010) have a bug with the dimensions tool. When we are creating single dimensions intermittently the dimension will create itself perpendicular to the length we have chosen, but with the same selection points (giving us a 0 value). Is anyone else experiencing this? This didn't used to happen in previous versions? Any help would be appreciated and apologies if this has been already brought up in previous topics. Please point in direction is so. Richard
