2,959 -
Posts posted by Bruce Kieffer
This is contradictory to what we are tough as the correct way to dimension objects, being done in VP annotations. The correct dimensions of 24-1/2", 3-1/4", and 1-1/4" were added on the design layer. The other wrong dimensions are the three added in the VP annotations. Is there a way to get the dimensions correct in the VP annotation?
I turned off Apple iCloud Documents and Desktop. Using that as a backup for my files is not worth all the other troubles, which I think are Sonoma related. I do have three rotating Time Machine backups. Anyway, so far so good without my VW files in iCloud.
1
I'm testing with 2024 update 3. I had it happen the other day, and yes, a restart always brings the cues back.
2
@Kevin K I'll give that a try. Thanks.
I'm now thinking this is not a Vectorworks issue but instead a iCloud issue. I saw some files created in the "I" folder that definitely were not Vectorworks. I continue to test, but so far the easiest solution for me will be to every so often empty that folder and hope that Apple fixes it soon.
I do have autosave now set to my local drive. I still have files I'm working on in iCloud. Really this should not be a problem. I continue to test.
Fingers crossed! I moved my .VWX autosave location out of iCloud and now the "I" folder is empty and staying empty. I might have been too happy! More .swap file are being created. It is for a referenced file. I will do more testing.
3 hours ago, Pat Stanford said:
@Bruce Kieffer For anyone but you I would recommend just faking it. 😉
=Truncate(Min(Height+.005, Length+.005, Width+.005), 2)Adding the extra 5 thousandths of an inch before truncating will make the Truncate act more like a Round. Anything with a digit in the thousandths place of 0, 1, 2, 3, 4 will end up with a value of 9 or less and will be ignored during the truncation. A digit tin the thousandths place of 5, 6, 7, 8, 9 will exceed 10 and will carry into the hundredths place and will truncate to the higher value.
It would be interesting to see what all those values are without the Truncate and see just how far off they are.
LOL! @Pat Stanford you know me too well. Sure I know they are 3/4" thick, but I want to understand what Vectorworks is doing, and you know that too!. I fixed all the pieces so there's no need for modification to the formula anymore. I do appreciate learning about the truncate formula, which I may use if the future.
1
I asked something similar to this about 6 months ago. @Pat Stanford explained to me that the thicknesses in my worksheet that I think to be 3/4" are actually slightly different than 3/4", and that is the case here. Instead of being exactly 3/4" some are .750000000000001, so when I summarize a column in my worksheet, those not exact and those that are exact appear as ---. How do I round them so they all appear as 3/4" in the worksheet? Without any luck, I tried all the worksheet cell number formatting options, and I tried changing the Units settings and using Dimension as the numbering format for those cells.
Column E is the thickness. When column A is not summarized, then they all appear as 3/4".
When column A (or column G) are summarized, then the thicknesses (column E) are all ---.
I use Keyboard Maestro which can make macros. I use it in Vectorworks. It's a Mac app, but maybe there's something similar for Windows.
1 hour ago, rDesign said:
@Bruce Kieffer like Zoomer suggested, are you using iCloud for either your working .VWX files or backup .VWX files?
A brief web search makes it sound like that Clouddocs folder is related to iCloud.It is possible. I will look, and if I am, I will excludes those files if I can.
I reinstalled Sonoma. The old .swap files are still there, but I need to test if new ones get deleted after a restart.
I restarted my iMac and the recently created .swap files are still in the "I" folder. This is not good. I see it ballooning again and filling my hard drive. I'm going to try reinstalling Sonoma.
4 minutes ago, zoomer said:
OK,
my whole CloudDocs Folder has only 10,8 MB.
Looks like my whole iCloud drive also has only 11,8 MB.
Do you use iCloud heavily and have upgraded storage.
(I think my default free account has only 5 GB)
And if, what could be the issue,
do you have VW cloud linked to iCloud or such things ?
I have a 200 GB iCloud storage account. I'm using about 90 GB of that. I researched ( a bit) what .swap files are; they are files used to supplement computer memory. The .swap files that Vectorworks is generating are huge compared to the apps.
5 hours ago, zoomer said:
Unfortunately I can't read the exact path from the screenshot.
@zoomer Here's the path, and the second screen shot shows the files that have been saved in the "I" folder since I deleted all the "I" folder contents yesterday. I have not yet quit Vectorworks, or restarted my computer to see if those files go away as they are suppose to. What I will say is that my computer is back to "normal" now that my HD is not full.
I found this morning that my 1TB HD was full. I knew I had close to 600GB of data and system, so I started search for what was consuming the rest of the drive. I found a fold inside my library folder that had 443GB. Yikes. It is titled "I", you can see the path in the screenshot. It was full of very old .vwx files and Vectorworks swap files. I deleted the entire contents. Now I'm watching the I folder, and when I save my Vectorworks file another .swap file is created. From what I had read on the internet, these files should disappear after a system reboot. I plan to test that. Anyway, what are swap files, do I need them. and is there a way to limited their creation?
2 hours ago, Gunther said:
@Bruce Kiefferare you using mac OS 14.x Sonoma?
Yes. 14.2.1
1
2 minutes ago, Pat Stanford said:
Then there seems to be a bug that is effecting you and not very many other people. At least I have not seen any other posts about it.
Standard trouble shooting is:
Reset Preferences (Reset button at the bottom left of VW Prefs)Run VW Updater app and choose Repair from the Advanced button on the center right.
Delete/Move User Folder
Delete and reinstall VW.
Good luck.I agree, and I will try those things. Support is working on this with me too.
11 minutes ago, Pat Stanford said:
The next time it happens, try double tapping the tilde ( ~ ) key and see if they return.
I did try that every time, and again the last time. They do not reappear.
@Claes Lundstrom I don't have Photoshop. @Pat Stanford I have them all checked like you do. Keep in mind snapping works for a while, maybe a day or two, then it stops.
1
Uploaded here too for others to see. I cannot grab the corners or other snap points.
It just happened again. I'll try to get a screen movie. OK, screen movie saved. I'm sending it to you @Josh Loy.
How do I dimension this VP correctly?
in General Discussion
Posted
@Pat Stanford I attached a file, but I think @Tom W. and @Elite Exhibits are correct that this type of dimensioning has to be done in the design layer.
Dimension this in a VP!.vwx
