2,816 -
- 1 reply
- 1
Is there a way to update a Current Date data tag?
Bruce Kieffer posted a topic in General Discussion
I realize I could delete and "set" a new version of the data tag. Just wondering if there's a faster way? -
Change Data Tag Style Text Color in RM?
Bruce Kieffer replied to Bruce Kieffer's topic in General Discussion
This is sad. I wish the designers would consider how the colors they choose affect color blind people. It's not just Vectorworks. I encounter this all the time. In this case it might be an easy fix to include allow changing the color in the interactive settings. I will post this "wish". -
Is there an interactive setting to change the color of the text for Data Tags in the RM? I can hardly see the color of the right hand text.
I often see two tool icons highlighted. I assume it's a bug.
Worksheet Title formula for Data Tag?
OK, so like I considered earlier, I set up a data tag to grab the text from the name field in the OIP. It's a bit of work, but easy enough. I copy the title of the worksheet, type into the OIP Name field "WS: " and then paste the worksheet title text. Then I associate the data tag to the worksheet. -
Snapping stops working when editing deeply nested objects.
Bruce Kieffer replied to Bruce Kieffer's question in Troubleshooting
I will file a bug report if I get it figured out. -
I just tired to create a simple file to send you @rDesign that would show the snapping problem. I opened a new blank file and placed a symbol that I have trouble snapping in my complex file when I drill into the symbol. No problems in the blank file, but still problems in my complex file. I don't know how to show you this problem easily. I will send you a file someday if I ever figure out how to reproduce it simply. -
Thanks @Pat Stanford I was hoping for a simpler solution in the provided data tag formula options. I'll give your method a try, but I may just use the "name" part in the OIP. -
Is there a formula I can use to make the title of a worksheet appear in a data tag. I know about #N# where I can add a name in the OIP, but I want Vectorworks to pick up the worksheet title given in the RM. This one:
@Tom W. How do I file a bug report?
