3,755 -
Everything posted by line-weight
Let's not get impatient... they've only had 5 years to fix it.
Creating solids from enclosing surfaces
line-weight replied to line-weight's question in Troubleshooting
This applies if I use the "true curve" rather than the faceted version for the path, right? Because, once it's been converted to a segmented version, the end profiles are no longer perpendicular to the end segments of the path. This started me thinking... is there a way to facet the path such that the end profiles *are* perpendicular to the end segments? If there is, could this mean that each section of the wall/viaduct could be constructed from an EAP rather than a lofted object? The advantage of this would be that having constructed your wall/viaduct, you could make alterations to the profile without having to rebuild everything including the path. As far as faceting the curve is concerned, I am thinking along these lines: I have just shown a circle quadrant rather than a NURBS curve, for simplicity, but I think the principle would be the same (?) Black is original "true" curve, green is the method of faceting used by the current script, blue is an alternative, which means that the end facets would be at right angles to the true curve at its endpoints. I expect there is some reason this wouldn't work! -
It seems to me that what you have come up with works as well as is possible within VW's limits and is a method that will be very useful to anyone trying to deal with this kind of geometry. I hope that some people at VW will take the time to go through it and understand it fully, most crucially understanding the problems that it solves. I think the principle of making things "exactly correct" at the control profile locations is sound. And then what happens in between them is 99.9% correct but most importantly does not create the horrible buckled, messy geometry that you highlight in your examples of why the seemingly most obvious approaches don't work. In my particular use case for this... the biggest test would be using it to try and create a junction between two converging viaducts. When they are only curving in plan, it's quite straightforward to see how to do this, but my brain starts to hurt when I try and think about the geometry if there are also curves in elevation. I'd be interested to see if you've managed to do something along those lines...but that perhaps should be a separate discussion. In any case thanks very much for your work on this! -
My next question is about drawing a NURBS path where it needs to transition from a straight line (or even a radiused curve). For example, let's say this is plan view, and the grey rectangles represent straight sections of wall, or viaduct, or whatever. I want to create a curved connecting section using a NURBS path. Drawing it in "interpolation point mode" doesn't work because (I think) there's no way to ensure that the ends of the NURBS curve are exactly square to the ends of the straight sections: However it can be done in "control point mode": If I then place a profile at each end of that NURBS curve ... how do I then find all the "parallel" curves? Because I have to draw them in interpolation mode. I'm not going to get the correct result by trying to draw an interpolated curve between two points. So I can split the curve and introduce a third profile in the middle somewhere. Will that give me a correct curve? Or is it a case of the "parallel curves" becoming more and more correct, the more intermediate profiles I introduce? I have been too lazy to try this for myself out before typing this post... but suspect it's something you've already gone into. -
Thanks. I guess that's what I'd 'intuitively' expect - that the more control profiles, the more accuracy. Do you feel you understand sufficiently the maths behind the way NURBS curves are constructed, to say that in theory (assuming all the profiles are perpendicular etc) the NURBS should all be exactly parallel? -
There's a question that this method raises for me: - I draw a NURBS path, through each of the control points I want - assume the profile, set perpendicular to the path, at each control, is exactly the same at each of those points - then I draw all of my other NURBS paths, using the vertices of the control profiles along the way - am I right in saying that all of those NURBS parts I've drawn are not necessarily exactly parallel? To test this I've made a very simple example... the profile is exactly square, 690 by 690. There's just a start profile, an end profile and a mid profile. It's curved in plan only. I've constructed the 'wall' using the method described. If I measure the width of that wall at each of the profiles, it's 690 as expected. But if I measure its width between each of the segment vertices (which ought to be at positions exactly on the 'generating' NURBS curves) then it varies very slightly... in this example between 687 and 691. Is that just an inevitable result of the way VW produces the NURBS curves? I expect that this is something which in practice usually wouldn't matter... but it might in certain use cases, and maybe it would become more marked with more complicated curves. I can see that maybe you could try generating the extra NURBS curves by doing them as a parallel offset from the originating one...would that work? I think it might when they are on a 2d plane but then things would get complicated in 3d. parallel-test.vwx -
In the meantime though - I've successfully built one of the sections and it looks good - nice clean geometry. Going to mess with things a bit now and try it on some different profiles. Your step 6 can be simplified a little, I think. Instead of creating 7 individual lofts - it seems to work to select all 7 lines as 'rails' in sequence - and then tick the "ruled" box as well as the others (this makes it join them with straight lines instead of a crazy loopy one) and then you can do the whole lot on one go. Unfortunately, it doesn't make a solid with end caps on - you still have to add these as you describe. -
I'm not managing to get the Marionette network to work - if I drop it in the file and press "run" or "select curves..." nothing happens. I've successfully converted to a menu command but choosing the menu command doesn't result in anything happening. It might be a result of it being converted to 2018? I do get this message when I copy the network into the file Not to worry though - I will continue through the steps using the nurbs-segmenting command I already had from before. -
Thanks! That all makes sense. Having understood your method, I can suggest a slightly different way, which avoids having to split the NURBS curve: 1) Activate working plane tool, planar face mode 2) Click on arbitrary point along NURBS curve to establish working plane perpendicular to curve at that point 3) Place a 3d locus at that point (ie where working plane and NURBS intersect 4) Select the locus > move 3D and make sure "cartesian" rather than "working plane" is ticked, and move the locus some distance along 'Z' 5) Now use that 3d locus as the reference point to rotate the working plane, in the same way you used the line drawn on the layer plane. -
Apologies to @axhake for taking so long to respond to this. I've finally found the time to sit down and look at it properly. As I'm still an upgrade refusenik, and using vw2018 I'm not able to open the attached files but that's fine, I think it would be good for me to test the method drawing somethig from scratch myself. The first thing to get right is the placement of the "control profiles". @axhake you say you have placed them "vertical and square to each of the control points". It strikes me that there are two ways that you might want to place these, if you are building a wall-like object that is curved both in plan and elevation: (a) The profiles are placed perpendicular to the path in plan and perpendicular to the path in elevation and and perpendicular to the horizon along the axis of the path (b) The profiles are placed perpendicular to the path in plan and perpendicular to the horizon in elevation and and perpendicular to the horizon along the axis of the path The diagram below shows what each looks like in elevation (for now ignoring any curve in plan) - think of the green line as a ground surface and the brown line the top of a wall built up from that surface. The red lines indicate the orientation of a constant-sized control profile in each case. I think I'd like to test this method for each scenario. My first question - what's the best way to get those profiles into location for each wall type? The first hurdle I've come to is a rather basic one: I can't work out how to generate a line that is perpendicular to a 3d NURBS curve in plan. This is easy with, say, a circle - if you draw a line starting at that circle, then one of the snap constraints you are offered is "perpendicular". This doesn't work with a NURBS curve though - am I missing something? I've discovered that you can get a 3d working plane that's perpendicular to the NURBS curve simply by using the Planar Face Mode and clicking on a point on the curve. The problem with this is that it has no regard for the horizon and it rotates as you go along the curve. Is there a quick and easy way to establish this working plane and then (for wall type a) tell it to rotate so its X axis is horizontal or (for wall type b) rotate so its X axis is horizontal and its Y axis is fully vertical? -
Enscape no good for those of us on Mac, unfortunately.
I think when I looked, you can still download it for free as long as you don't use it for commercial work.
How much time do you reckon I'd need to invest in it, to have a mess around and get an idea of how it works? An afternoon, or a couple of days?
How to control two roof faces intersection ?
line-weight replied to Stéphane's question in Troubleshooting
Thanks. One of my biggest everyday annoyances with VW is the push-pull tool not finding faces when it should. If sorting these things out would improve this, it would make a big difference to the general user experience working in 3d.- 94 replies
- roof
- combine/connect
(and 1 more)
Tagged with:
Thanks for this. I think you can probably add to that, that the same happens with invisible slab components (I've just noticed this now) I wonder if this is behind the troubles with the push-pull tool that were first noted at least 4 years ago:- 94 replies
- roof
- combine/connect
(and 1 more)
Tagged with:
- 94 replies
- roof
- combine/connect
(and 1 more)
Tagged with:
Here's yet another roof face problem. See the attached file. Look at the sheet layer with the section on it. For me it looks like this: You can see I've labelled two roof face objects. Now look at the saved view "3d view": The roof face objects are not there. They exist in the section but not in the 3d view. They aren't visible in top-plan view either. That remains the case with all classes and layers set to visible. These are objects that previously existed - then they just disappeared. I didn't delete them. Now, I can't actually get rid of them from the section, because I can't select them. [edit to add: I have now got rid of them by tools>custom modification>select by type=roof face, move them to a temporary layer, then delete that layer] This is in VW2018 and I don't know if this will replicate in later versions. At present my feeling is that the roof face object is unusable. I'm certainly going to stop using them altogether in this project. ghost_roof.vwx- 94 replies
- roof
- combine/connect
(and 1 more)
Tagged with:
I don't know, I don't attempt to use either of those features.- 94 replies
- roof
- combine/connect
(and 1 more)
Tagged with:
I wish that *all* multicomponent layered objects would let you choose to adjust the geometry of each layer independently and manually if you wanted. That includes walls. An example where the wall tool falls apart - a dormer cheek, where you might want the inner layer to extend between floor and ceiling (and be rectangular in elevation) and where you want the outer layer to run between eaves and roof pitch line (so be triangular in elevation). Or any number of variations on that theme. At this point, I just give up on the wall tool, and have to build it manually from directly modelled objects. Same sort of situation arises with roofs too. Sometimes you just want to tell VW manually where each component needs to extend to. As soon as you give up and build the thing out of directly modelled objects, of course you lose all the convenience of easily cutting window openings through multiple layers.- 94 replies
- 1
- roof
- combine/connect
(and 1 more)
Tagged with:
If this makes the Mac Mini viable for Vectorworks again that would be great! I'm hoping my refurbed 2009 mac pro can hold out just a bit longer, and I can make the jump straight from that (and VW2018 on El Capitan) to VW2022 on an M1 mac. Maybe even a mac mini.
Oh yeah and something similar to this: using the push-pull tool, I think that faces of wall components in invisible classes are in some way snappable, or at least the push-pull tool finds those faces - as seen in this screenshot (VW2018)- 94 replies
- roof
- combine/connect
(and 1 more)
Tagged with:
@Matt Panzer I know we are supposed to go through the "bug submit" process - the reason, very briefly, I'm often reluctant to do this, is it takes up a load of extra time, repeating what has already been written out in a forum thread like this. And if I'm going to spend that time writing something up, I'd rather write it up on a forum thread where other users can read, comment and perhaps benefit, than submit it into the ether where I may never hear anything again. Because so many bugs don't get fixed for years and years, it's better to have a public record of them, so that at least people can find the thread, understand that there's a certain problem with that tool, and maybe decide not to waste time trying to use it. I feel it should be the job of VW to do the admin of getting the bug logged into the system. After all, it's VW that's supplying the product that doesn't work, and users don't get paid for the time they spend writing up problems. Not in any way a criticism of you or other VW employees - I would rather this message reached the people who make the decisions about how things are resourced, including how many VW staff are given sufficient time to properly read and respond to problems raised in the forums. Thanks for your help on this so far though.- 94 replies
- 2
- roof
- combine/connect
(and 1 more)
Tagged with:
- if I move either face away and back, in top-plan view, nothing changes. - if I move the grey roof face away and back, in a 3d view, then the problem does go away when I look at it in top-plan again - if I move the brown roof face away and back, in a 3d view, then the problem doesn't go away when I look at it in top-plan again. Some other things you can try replicating: 1) open file, don't move anything 2) use the combine-connect tool in either vertical or mitre joint mode, to try connecting the two roofs 3)the brown one turns into a thin sliver and 1) open the file, do the move-away-and-back process on the grey roof face to "fix" it 2) use the combine-connect tool in either vertical or mitre joint mode, to try connecting the two roofs 3) the brown one gets a big bite taken out of it and 1) open the file, keep it in top-plan view 2) use the connect-combine tool to connect the two faces, vertical mode (still in top plan view) 3) Note that the connection line moves 4) View in 3d: a correct connection has happened, with the faces aligned at their top face 5) staying in 3d view, using the connect-combine tool alternately between vertical and mitred join mode seems to function correctly. In amongst trying all this, I got to a point where using the combine-connect tool in vertical and mitred mode alternately did not work properly (the mitred mode refused to change anything and it stayed as a vertical join, which seems to replicate @Stéphane's problem.... however, I could then not remember the exact steps I took to get to that point! I have not got time to test further at this stage but maybe some of the above will provide some clues?- 94 replies
- roof
- combine/connect
(and 1 more)
Tagged with:
@Matt Panzer if we are on a roll with bug checking, are you able to replicate the problem I describe in the thread I linked to yesterday, with roof faces being drawn incorrectly? https://forum.vectorworks.net/index.php?/topic/73056-is-vw-drawing-this-roof-face-wrongly/- 94 replies
- 1
- roof
- combine/connect
(and 1 more)
Tagged with:
Thanks.- 94 replies
- 1
- roof
- combine/connect
(and 1 more)
Tagged with:
