yasin2ray
    150
Reputation
80 Excellent
2 Followers
Personal Information
  • Occupation
    Landscape Architect
  • Homepage
    futurityinc.com
  • Location
    United States
Recent Profile Visitors
  1. I wish a viewport visibility setting could be transferred through the Resource Manager. It would be a much easier way to get viewport visibility from one file to another. As of now, I open the two files I need to work with and use the Eyedropper Tool to pick up and apply the viewport visibility from one file's viewport to another file's viewport. But if my coworker is working in the file I need, I have to wait until the file is closed and available. I appears that this might be almost ready to accomplish given the tools and setup that is already established. Thanks! Anna
  2. I'd love to have the Navigation Palette option to "Show/Snap/Select" that would come between Show/Snap and Show/Snap/Modify. I use the Show/Snap option when I need to ensure that I don't accidentally modify something while working, but I often while working want to select something and check on: The data record and field info attached. The class and/or layer it is on. I can only select the object to see this info when in Show/Snap/Modify mode, but that leaves my working environment unprotected; I could accidentally modify it while looking at its info. Thank you for considering this improvement. Anna
  3. @Pat Stanford This worked! Thank you. (Once I get my v2025 installation bug resolved and I can begin using v2025, I'll use the version you first posted). Thanks, Anna
  4. @Pat Stanford, I'm trying to make this right now and it's not working. I see I do not have the option to select the first radio button for Formula. My options are Calculated field or User-entered field. Anna
  5. I am organizing and reviewing our set of worksheets. I have them placed in design space. I'd like to be able to place a data tag on each one to show the name of the Worksheet Image symbol. I haven't been able to figure out what criteria to use to display that info. What is it? Thanks! Anna (Vw v2024)
  6. @bgoff: Are you saying to make a plant symbol for each plant in the seed mix? That would be 40 plants in one seed mix and 43 plants in the other seed mix, and we specify a blend of the two seed mixes. I'd rather not try to make a plant mix to match what we specify. How would recommend I get volume of seed mix needed? I have this set up already with my own record format but it would be nice to be able to make more use of Landscape Area Styles, which use Landscape Areas. Thanks, Anna
  7. Landscape Area Styles do not appear to be able to handle a seed mix. I need Landscape Areas for lawn seed and a native plant seed mix. Landscape Area Styles focus on a single or multiple plant species. it's based on the 'Plant Record'. I don't want to use a plant symbol as a seed mix. I'd have to price the seed mix by cost per square foot instead of 'x pounds per 1000 square feet'. That's too wonky. How do you calculate areas of landscape that will receive seed? Or a mix of two seed types? Anna
  8. It would be nice if the Landscape Area Style and the Hardscape Style were formatted the same for the things they both need to handle. Such as a basic price per square foot. ---Hardscape Style has a section for pricing. ---The Landscape Area Style does not have a place to set pricing. You can add price to the Materials that are components of a Style. I'm still trying to figure out where that pricing shows up. AND Landscape Area Styles are not equipped to handle a seed mix. I need Landscape Areas for lawn seed and a native plant seed mix. So there is definitely no way that I can see to handle pricing for those. Anna
  9. @Pat Stanford, but will the image be georeferenced? I want to add an aerial image/orthophoto from Google to my georeferenced document. I need it to land in the correct location in my vwx file. Anna
  10. @Mark Flamer @Patrick Winkler Does anyone have basic instructions for how to use the marionette in this file to get an image from a different URL (a different location)? I'm looking at what's in the file "ImageFromURL.vwx" and trying to play with it to understand how to use it. I have a URL for a different location. I don't see where put the URL in the Marionette set to get the new bitmap output. The file is great, but it needs instructions to make it useful. THANKS!
  11. The automatic size of the heads of the arrows in my site model is so small the arrow lines look like lines only, no arrow. I see there is no setting for changing this. Is there a pre-step or roundabout way to get the arrowheads in the site model to be bigger? Anna
  12. Pat, Nothing complicated here. Sometimes the worksheet that is on a sheet is not the one I want. With symbols, we can select the symbol and in the OIP, select "Replace", and replace the symbol with another symbol. I want to be able to do this with worksheets. Worksheets have only one insertion point (to my chagrin!!! That's another request I have made) so it should be easy to swap out one with another through the OIP Replace button. Without that, to replace a worksheet I drag down the one I want, place the insertion at the same place as the one that's already there or just anywhere, then delete the worksheet that I didn't want on the sheet. Anna
  13. Paul, The file that you are importing into, have you set an Internal Origin or an adjusted User Origin prior to the Lidar import? We often import Lidar into our files for our landscape architecture projects. I set the EPSG code and the Internal Origin prior to the Lidar import BUT YOU CANNOT set the User Origin until AFTER the Lidar has been imported.
